The Gray-1, A Computer Composed Entirely Of ROM And RAM
When we learn about the internals of a microprocessor, we are shown a diagram that resembles the 8-bit devices of the 1970s. There will be an ALU, a program counter, a set of registers, and address and data line decoders. Most of us never go significantly further into the nuances of more modern processors because there is no need. All a processor needs to be is a black box, unless it has particularly sparked your interest or you are working in bare-metal assembly language.
We imagine our simple microprocessor as built from logic gates, and indeed there have been many projects on these pages that create working processors from piles of 74 series chips. But just occasionally a project comes along that reminds us there is more than one way to build a computer, and our subject today is just such a moment. [Olivier Bailleux] has created his “Gray-1”, a processor whose only active components are memory chips, both ROM and RAM.
The clever part comes with the descriptions of how the ROMs are used to recreate the different functions of the processor, through careful programming. Some functions such as registers for example use loops, in which some of the address lines are driven from the data lines to maintain the ROM at a set location. The name of the computer comes from its program counter, which counts in Gray code.
The full processor implements a RISC architecture, and there is a simulator to allow code development without a physical unit. The write-up is both comprehensive and accessible, and makes a fascinating read.
It’s safe to say this is the only processor we’ve seen with this novel approach to architecture. Some more conventional previous features though have been an effort to create a processor entirely from NAND gates, and another made from 74 logic.
49 thoughts on “The Gray-1, A Computer Composed Entirely Of ROM And RAM
  1. this reminds me of a weird idea I had… if some kind of very basic processor could be made entirely out of power transistors. (more specifically, TO-3 packaged ones). Is it even possible? If so, it would be neat to see… just how crazy it would be. Also curious how much power it would require to run.
    1. This guy built a 6502 out of discrete transistors – looks like he used something surface mount, though.
      http://hackaday.com/2016/05/16/a-dis-integrated-6502/
      If you built a 6502 out of TO-3s (maybe with some blinky LEDs like the project in the link above), you could put a glass top on it and use it as a dining room table. And, of course, if you do end up building a 6502 out of TO-3 transistors and make it the size of a dining room table, I’d like to see it.
      1. A discrete computer turned into a dining room ?
        That creates a LOT of problems, like : “will we ever eat ?” “not until I have checked the halting conditions of this random blinkenligh program”
        OTOH this could solve the “plate warming” problem, as the food will stay warm :-D
    2. Why not ?
      I’m trying to design a discrete computer with Ge transistors, https://hackaday.io/project/13409-germanium-ecl/ and TO3 transistors might be as slow, yet more space-consuming :-D
      As for the current : you don’t need to run them at full power, 5 to 10mA might be enough.
      https://hackaday.io/project/8449-hackaday-ttlers has more links to discrete computers, look at the contributors of the project and check their totally crazy ideas :-D
  2. this reminds me of a weird idea I had… if some kind of very basic processor could be made entirely out of power transistors. (more specifically, TO-3 packaged ones). Is it even possible? If so, it would be neat to see… just how crazy it would be. Also curious how much power it would require to run.
      1. It seems pretty much like an FPGA implementation with the LUT’s. The most conspicuous difference is the lack of physical registers though. I bet it is a beast to close timing on!
        1. Thinking more about this, the number of address lines going into a ROM/RAM chip are not that many. This means that you would not get many LUT’s per device using the FPGA LUT methodology. The FPGAs that I use have probably got 7 or 8 lines going into each LUT, with a single bit output. This would mean that a 64K ROM/RAM would only provide 2 LUT’s each. Something else must be going on here.
      2. Well at the very least it allows for a more concrete understanding of how FPGA works.
        Now we can tell students that FPGAs are just a bunch of ROM and RAM chips shoved into a tiny package :P
  3. Ah now that is a beautiful piece of work, I’ve had one running in a sim for a while but I’ve never built it in actual hardware or had to deal with the real world complexity that entails.
    Mine just uses RAM so when you turn it off there is nothing left, no computer and no data, more secure then an iPhone. ;-) And yeah you need to halt it and inject the state machine then let it run, so it is the ultimate in reconfigurable hardware.
      1. It was a component level sim, I called it RAMB0. It was to settle an argument as to how simple and compact a computing substrate could be therefore how probable it was that machine intelligence could spontaneously arise somewhere in the universe. Memory doesn’t need to be a fixed structure either, it just needs to be a mechanism to allow for the propagation of a self interacting pattern through time. This means that the limits are way down at the sub atomic level in virtual particle pairs amongst the quantum foam, so very small indeed, and everywhere in the universe, even in apparently empty space. This leads to the conclusion that the entire universe must already be a computer and probably sentient.
  4. Reminds me of an old Z80 hack for cpu 16 bit output, the BC registers were expressed on the
    address lines with the relevant instruction encoded via the data line & appropriate sync
    with processor signal lines. ie Look for that instruction & latch the full 16 bit address lines for
    output only with a little specialised hardware.
    I built that add on for an embedded one running CP/M in 1982 in a console in front of the gear
    lever in a 9172 Ford Escort – the cpu non maskable interrupt (NMI) line ran from the distributor
    ignition signal ostensibly to fire injectors with all the auto electrical fruit from a VW combi usin
    Bosch parts mostly… It worked in a fashion but not ideal, part of my EE thesis – still in the library
    of the now Curtin University, Bentley Western Australia (used to be W.A.I.T)…
    The BC register pair was used to drive 8 off 7-segment LEDs multiplexed. The cpu’s NMI line
    also switched Z80 EPROM code space between CP/M & injector code. Air Flow Meter was a
    restrictive flap type not ideal at all for a ford escort inlet manifold & I kept the carbie as a backup…
    The ROM/RAM coding issue was used in a table to “decide” upon flags for the EFI state
    machine side. Its an old technique and with care re flag states & semiconductor timing is fully
    deterministic though simple whereas current operating systems & some embedded systems
    seem to take on a more unsettling probabilistic paradigm :/
    The ROM/RAM approach was also trialed for ascii graphic character recognition in
    a Universal Adaptive Logic Circuit (UALC) simulation on a KL-10 running tops 10 (by DecSystems)
    but, there we had some basic code to tally up the match hits on the image ram to show
    a recognition probability the asci character graphic was one of the 26, upper case only.
    Clunky with slow user interface having to type the row/column to enter the graphic pages
    but worked to a good degree…
    iirc
    Hewlett Packard used a similar rom/ram decoding as part of their micro word architecture
    for their first Silicon on Sapphire 32 bit micros – circa mid 1980s…
    1. Need an edit feature please… ?
      Doh 1972 Ford Escort Mark 1.
      1600 dual down draft progressive carb with bottom of the manifold milled to
      take 4 off 2L VW combi injectors…
      Couldnt run any floppy io whilst engine running, Cp/M command line for inspection
      re peek & poke etc…
  5. Curious readers will have noticed that SD cards and the PROM storage on their NanoPi’s and BBBs are called NAND storage, implying a connection between PROM and NAND gates.
    ROMs made with wired connections – “fusible link ROM” – can do any combinatorial logic function. It is all lookup table. The input is the address of the output.
    Cool project. Actually building it and working out the whole thing is great. This was called microcode in the old days, and would have taken a full time team at DEC a couple years!
    1. And these days it seems all the USB flash has almost the same type
      of 32 bit micro handling the flash reliability with records of past failures
      and the code set looks suspiciously like code variants of 8/16 bit 8051
      [I understand the code can be quite sophisticated, moving stuff around
      as a consequence of its own internal scans (not observed outside the
      device) to ensure data reliability…]
      It should be noted there are many possible data hacks here allowing
      all sorts of intrustions & opportunity for identity theft , such as:-
      1. The USB flash device reporting its 8G when its really 32 G, thus allowing
      the embedded micro (with the help of a driver that ostensibly runs & registry
      scan & “backs” up to that same USB) scanning your HD & any connected devices
      for anything that looks like passwords, personal data eg resume’s, bills, trade
      data, myob, excel files eg stock trade data, FP markets. XTrade logs etc
      2. Hiding various DLLs & other system compatible code in a hidden partition
      even if it doesn’t overtly make wrong claims of its size as in 1 & then if the
      occasion arises making this “available” to svchosts & other windows programs
      as well as matching a subsequent driver “upgrade” for non related devices.
      3. Other, best I not mention but, can be found (I am told) on high end hack
      forums…
      As always buyer beware, now its user beware – as in determinism becomes lost !
      Someone should design a large scale USB intercepter that has a large rom/ram
      space to trap data patterns in same format as the virus scans we are used too…
  6. Why do people waste their time with projects like this? If you want to build/mimic an (e.g.) Micro-Controller “Core”, depending on the scale, just use a simple programmable logic device (e.g., CPLD/FPGA). I’ll never understand this mentality.
    1. who do people like you waste your time commenting anti-hack mottos on a CLEARLY pro-hack website? did you notice the URL… hackaday…
      you will never understand that mentality because it is not the mentality of the article at all, it is not about building a core of any kind at all; it is about using an oldfashioned ROM/PROM/EPROM (but not EEPROM) chip for something other then “use-by-CPU”.
      maybe your frustrated cuz you need a little bit more then a software-download to make it work enough to prove something? maybe the author started the entire project with the specific intent of pissing YOU off, as the rest of us enjoy HACKS on HACKaday.
      PS: i love the idea of ROM as complex decoder logic, cheap(er) as/then chips (pun intended) and impossible to work with for people that cant take thier hands off of thier keyboards and internet-connections long enough to connect 30-40 wires in a breadboard. (nothing to track, infect, or update)
  7. A great problem to get started with this kind of thing is: How would you use a ROM to add “instant” multiplication to a micro? In fact, use a ROM to convert lower case to upper case and ASCII values to numerals and any other conversions or simple calculations that normally take some addition and/or branching. You need a micro with address and data bus, and you can add a lot of really cool and very fast features with a PROM/ROM.
  8. I had once obtained a precision absolute pressure transducer that had a serial 16 bit output with 14 bits used for the binary value. I built a circuit with a 16 bit shift register that was used to address a 64Kbyte eprom that I programmed with the 4 digit bcd value of the barometric pressure. Then a 2 bit counter to drive the A0 and A1 lines to readout the value to 4 bcd to 7 segment decoders for an LED display. I had a lot of fun with that project.
    1. Well done, an elegant solution in its simplicity of implementation no processor
      required. Talk to graduates even 20 years ago & they had great difficulty thinking
      up a solution from discrete logic as uni’s of the day focused on bloated dev kits
      centralised around the latest leading edge micros with all the overhead. Its even
      harder these days in the engineering sphere to impress that an i7 embedded running
      WIn 10 isn’t necessary for a simple piece of gear to do a simple safe industrial interface
      task with linear/rotary positioning – especially as so many out there etc…
      I used to be engineering manager of Pretron electronics circa 1985, we used cheapest
      simple optical quadrature encoders which we made ourselves from acrylic disks & photo
      sensors used for press-brake back-gauging for positioning metal sheets prior to bending.
      Conventional readouts used complex discrete logic & proprietary LED interfaces. A local
      co came up with a dead simple low cost design with a front end 74C86 & 2 resistors/2 caps
      to delay edges of the quadrature feed such that it produced a combined 4 bit parallel
      value feed into a MC68705 CPU with minor TTL to produce an interrupt whenever the
      4 bit pattern changed such that the CPU multiplexing of the LEDs wasn’t interrupted unless
      a change in position occurred but, even large positional changes were accommodated
      so fast one couldn’t see any flicker – all this for 0.1mm resolution metal positioning for bends.
      The display decoding used almost exactly the same format as you describe re pressure
      but for segment decoding into an array as the CPU had plenty of parallel output lines…
      We also did brushless motor control & theorised the same means could be used to lookup
      the motor’s PWM values from a (large) segmented table which got its address from the delta
      position re current position & set-point ie No need for PID for the cheapest simplest setup.
      The curve of the values in memory previously determined/checked could be fixed in rom for a
      particular motor characteristics in a narrow dynamic range utility environment or in ram (from
      a rom backup init) with of course means to amend the table to deal with mechanical changes
      such as spring constant, loading outside settling range & power fluctuations etc. This approach
      minimised CPU overhead & offered a system with intrinsic stability not dependent on CPU
      computations other than subtraction. This allowed the CPU to also offer background code for
      things like reporting stats re job use for the press-brake, logging etc
      Although elegant we never produced one – the technical director preferring a very
      expensive but facile “bought one” ie not one that we could use & market which had many
      superior options :/ Nuff said about that lost opportunity.
      These days many of these variations already used & patents well expired :shrug:
      1. I have to agree with you on some of the younger grads. The tendency is to use an FPGA when a few gates will do. There also seems to be a real lack of understanding of analog/power circuitry.
        1. Indeed Eugene :-)
          My tutor at WAIT (Now Curtin Uni Bentley, Western Australia) back then 1979 Ian James got a
          request to design an HP-1000 bus to HPIB/Serial interface to drive a largish A0 sized flat-bed
          plotter & from an architectural co that had a couple of 19″ rack cabinet HP-1000’s with tape
          drives & a whopping 10MByte removable platter. They’d exhausted local design firms that
          wanted to use CP/M Northstar computers to do the job & a couple of co’s in US that wanted
          to supply a $5000 interface that a simple plugin card *should* handle. He selected me as I
          had some patience to deal with odd ball convergent approaches irreverent of tradition ;-)
          We ended up designing a plug-in card with about 11 discrete LS chips & a UART on a
          wire wrap board – no external $3000 CP/M North star with its 12MByte 8″ floppies & at a
          lot less too – I got paid, Ian got his dept qudos and whilst at it I wrote Xcom (did a figure
          of 8 x 8 poll at 4MHz yet did 19200 Baud fine on many (~8) devices) for 8080/Z80 to provide
          a telnet like comms session across many Northstar/Amiga desktops – just needed a ‘hub’
          for switchable RS232 devices, in those days no mean feat as many handshake lines
          “got in the way” so the h/shake lines got fudged by loop backs so they didnt matter *grin*
          What bothered me about the other co’s was their reliance on latest populist tech that
          had nil Provenance with an unclear development pathway – all I did was analyse, simplify
          with the benefit of a couple of hrs of truth tables linked to code segments in a classic
          state machine architecture. Thing is all this in contemporary uni text books all over the
          place yet never read it seems by competitors – as mercans say so often – go figure ;-)
          That was all decades ago, now I fart around with day trading but, still get my end in now
          & then re strange designs much removed from electronics into biochem realm – go figure that…
  9. Very nice piece of work, very interesting. It is a practical demonstration, but it is not practical in the usual meaning of practice. Thanks for sharing it with others. Thank you.
Leave a Reply to Yann Guidon / YGDES Cancel reply
