Toast-Bot Butters For You (Sometimes)
Sometimes — despite impracticality, safety, failure, and general good sense — one has an urge to see a project through for the sake of it. When you’re sick of buttering your toast every morning, you might take a leaf out of Rick Sandc– ahem, [William Osman]’s book and build a toast-bot to take care of the task for you.
[Osman] — opting for nail the overkill quotient — is using a reciprocating saw motor to hold the butter while the toast moves underneath the apparatus on a platform controlled by a linear stepper motor. The frame and mounts for Toast-Bot were cut out of wood on his home-built laser cutter — affectionately named Retina Smelter 9000′ — and assembled after some frustration and application of zip-ties. The final result DOES butter toast, but — well — see for yourself.
Despite working with only margerine-al (sorry!) success from a practical standpoint — equally inclined to shred or butter — we are inclined to chalk this up as a win regardless. A robot doesn’t always need to be perfect to prove that it can be done — especially if it does the job in a deliberately comedic fashion.
11 thoughts on “Toast-Bot Butters For You (Sometimes)
Leave a Reply to MystickCancel reply
