Working mostly in metal as he does, [Tuomas Soikkeli] has invested in some nice tools. So when his sweet magnetic-base drill was in need of a new home, he built this two-in-one drilling station to maximize shop space and add some versatility to boot.
For the non-metalworkers out there, a mag-base drill is basically a portable drill press where the base is replaced with a strong electromagnet like the one shown here. They’re often used in the construction trades to drill holes in steel beams or columns, and often include nice features like a built-in coolant system.
[Tuomas] effectively turned his mag-base drill into a very beefy drill press by mounting it to a disused miter saw stand. A thick piece of plate steel forms the base, and with holes and drain channels machined into it, used coolant can be captured in a drain pan below for reuse. A second base for a benchtop drill press means he’s got a dry drilling station too, and the original support arms on the miter stand are ready for drilling long stock. The drawer below the dry side is a nice touch too.
There’s a lot to learn about fabrication from [Tuomas]’ video and the others on his channel, which is well worth checking out. And if you want to convert your drill press into a mag-base drill, why not check out this microwave oven transformer to electromagnetic crane project for inspiration?
Why there is no comments here after 24h ? Maybe if some guy strap some shit to electric dc motor there will be more?
Most readers are probably “non-metalworkers”, that’s why there’s a lack of comments.
Most of the projects on HaD are electronic in nature, maybe some 3D printed parts here or there. Not a lot of heavy metal work or machining. This site is definitely a product of the Arduino/Pi generation, for better or worse.
That Skilsaw is pretty impressive, going 1/4 or 3/8 steel like that.
