Logic Analyzer Pushes The Limits Of Miniaturization
Careful not to sneeze while using this diminutive logic analyzer — you could send it flying across the bench.
Undertaken more for the challenge than as a practical bench tool, [Uwe Hermann]’s tiny logic analyzer is an object lesson on getting a usable circuit as small as possible. Sure, some sacrifices had to be made; it’s only an eight-channel instrument without any kind of input protection at all, and lacks niceties like an EEPROM. But that allows it to fit on a mere 11 x 11-mm fleck of PCB. That’s a pretty impressive feat of miniaturization, given that the Cypress microcontroller running the show is in QFN package that takes up 64-mm² all by itself. A micro-USB connector takes up much of the back side of the board and allows the analyzer to talk to sigrok, an open-source signal analysis suite.
Everything about the project is totally open, including the PCB files, so you can build your own if you feel up to the challenge. We’d strongly suggest you check out this primer on logic analyzers first, though, especially since it focuses on the capabilities of the sigrok suite.
9 thoughts on “Logic Analyzer Pushes The Limits Of Miniaturization
    1. The design intentionally sacrifices a lot of things (no EEPROM, no input protection, various Cypress hardware recommendations are ignored) in order to be able to make it very tiny.
      Please read the original blog post. I don’t think he could do it better on a 2 layer board this small.
  1. Given the size, input protection could easily be integrated in a modular fashion into the cabling. After all, it’s just a logical extension (har har) of the way analog ‘scope probes require matching considerations, and/or have in-line filtering components added, etc.
Leave a Reply to OstracusCancel reply
