Does your pet get distressed when you’re not home? Or, perhaps their good behaviour slips when you’re not around and they cause a ruckus for the neighbours. Well, [jenfoxbot] has just such a dog, so she built a ‘bark back’ IoT pet monitor to keep an eye on him while she’s out.
The brains and backbone of the pet monitor is the ever-popular Raspberry Pi 3. A Sparkfun MEMS microphone breakout board listens for any unruly behaviour, with an MCP3002 analog to digital converter chip reading the mic input. Some trial-and-error coding allowed her to set a noise threshold that — once exceeded — will trigger an audio file, shushing her dog. It also logs events and uploads any status updates to a CloudMQTT server to be monitored while away from home. Her Imgur build album can be found here, and the GitHub project page is here if you want to build your own!
Check out the demo video after the break, that was probably confusing for her good dog, Marley.
We’ve previously featured a web-connected treat dispenser, but what kind of treat would you give to a robotic pet?
[Via /r/DIY]
“Does your pet get distressed when you’re not home?”
Get a pet for your pet.
Two dogs are less stressed than one.
Unless they hate each other, of course. :-)
Or a less hungry one when you consider buying a fish for your cat.
This breadboard and flat cable setup is not “dog-proof”,
since there is a raspberry-pi, use a usb microphone for sound input, it’s more reliable than this.
Could be done with a comparator and something like an ISD1820. Still a good hack though.
