This one is clearly from the “it’s all fun and games until someone loses an eye” file, and it’s a bit of a departure from [Make It Extreme]’s usual focus on building tools for the shop. But what’s the point of having a well-equipped shop if you don’t build cool things, like this unique homebrew electric gun?
When we hear “electric gun” around here, we naturally think of the rail guns and coil guns we feature on a regular basis, which use stored electric charge to accelerate a projectile using electromagnetic forces. This gun is much simpler than that, using purely mechanical means to accelerate the projectiles. The heart of the unit is a machined aluminum spiral from an old scroll compressor, which uses interleaved orbiting spirals to compress gasses. This scroll was cut down to reduce its mass and fixed to a complex shaft assembly allowing it to spin up to tremendous speed with a powerful electric motor. A hopper feeds the marble-sized ammo into the eye of the scroll, which spits it out at high speed. Lacking a barrel, the gun can only spew rounds in the general direction of the target, but it makes up for inaccuracy with an impressive rate of fire — 100 rounds downrange in two seconds. It’s pretty powerful, too, judging by the divots in the sheet steel target in the video below.
Like all of [Make It Extreme]’s build, a lot of effort went into this, and it shows. Their other fun builds of dubious safety include these electromagnetic wall climbers and these “Go Go Gadget” legs.
That was….. satisfying to watch.
As someone who walks through a large machine shop to get to my workplace, it was interesting to watch.
I think it was a well done video, too bad more videos aren’t done that way.
No! This is NOT a well done video. First you show off the thing you have built in action. THEN you show the build process.
Nice job. But it wont stop the zombies.
Need fast and more power. ( Exploding pellets might help.)
You have to save us from the zombies.
Please help use you are humanity’s last hope.
Dam correction.. ” use” is “us”…
Flechettes instead of pellets. Aim for the neck, the head will drop right off after a 20-round burst.
Not that I have experience in that field….just speculating.
I liked the idea in “The Day of the Triffids” – a gun throwing a spinning, sharp-edged metal disc to decapitate Triffids.
I feel like a fool, but I still can’t figure out how this thing flings the marbles in remotely the right direction. Why don’t they spray everywhere?
Centrifugal force pushes the marble against the outermost wall. When there’s no wall to hold back the marble, it just keeps going…
I guess the feeder works as a barrel and that the direction can be calibrated by adjusting the fixed scroll?
Can’t get much precision but then I don’t think they ever intended to have a precise weapon ;P
As others have said, the top piece has a scroll race which spins rapidly. The bottom plate has a straight race that does not move. The races are both sized to be roughly half the diameter of the ball. Thus, for the ball to exit the device, it gets guided along the straight race as the scroll race pushes it out to ever widening circumferences until it exits. Here’s a slightly different execution, but a similar concept from the slingshot channel that illustrates things (it’s basically a reverse configuration): https://www.youtube.com/watch?v=LH8G7atCFSQ
Ah, that explains it. I wasn’t paying close attention and I didn’t realize the spinning piece was the one with the straight radial cut. Joerg’s model really clarified that and I knew what to look for when I went back to the original video. Thanks!
kind of reminds me of the exploding frisbee gun from unreal tournament
Why would anyone want an exploding gun? B^)
Unless you are leaving it for your enemy to find… B^)
Nice, it’d be interesting to see how much accuracy could be improved with a barrel.
BTDT – US Military calls it the MPDS or Multiple Projectile Delivery System nicknamed “DREAD”. Here’s some limited backgrounding on it:
https://www.youtube.com/watch?v=ztQpnyhkASY
https://goo.gl/dtjQsy
Because it’s hopper-fed it can’t be used sideways gangsta-style. (c:
Just kidding. It’s an awesome build. For most of the video I couldn’t tell what they were trying to do. I mean I knew they’re building a pellet gun, but I couldn’t tell the design.
These guys look like the bored engineers from the West Hartford CT machine-shop plant that builds the DREAD for Colt Firearms US defense contractor down the block or two. Some how they got a hold of the patent (#6520169 dated 2003) and wanted to duplicate St George’s invention but a mini version. Impressive work and looks like a paintball gun too. You’re right, you can’t hold it Center Axis Relock style or the bearings won’t have gravity-feed anymore. They wont fall out though.
Supposedly USAF can use this for satellite-killers. No recoil to throw off sat attitude. However gyroscopic forces will throw off the bird a bit if no counter rotation employed. I really don’t know how these guys found the time to dabble with this project.
They are Mike and George M. from island of Cyprus. They are the coolest machine shop guys I’ve ever seen. They love the MiGtronics welders. They can make almost anything you can imagine.
Counter-rotation? Sounds like an opportunity for double shots to me. B^)
Rollyn01- Just like the new USN/USMarines KAMAN robot helicopter (KMAX), you have to have counter-rotating rotors to mitigate gyroscopic rotation. It does not have to be on the main ball bearing chamber, just above or below it to prevent the thing from rotating the whole satellite. There is no recoil too as it acts like a David and Goliath rock sling.Only the rocks are metal golf balls with dimples.The trauma to the target is massive and mostly silent in-flight (when slowed down from super-sonic).
http://i1.wp.com/mechstuff.com/wp-content/uploads/2016/07/Kaman-K-MAX.jpg
Isn’t there a less portable version of this in some old Popular Mechanics reprint/pdf?
Yes – 1963
https://i1.wp.com/boingboing.net/images/electricbbcannonme4.jpg
I found the battery mounts the most interesting part of the build. maybe I’m lame like that.
loving the very smooth lathe time-lapse footage!
