A Cartoon-ifying Camera For Instant Absurdism
We take photographs as a way to freeze moments in time and to capture the details that get blurred by our unreliable memories. There is little room for interpretation, and this is kind of the whole point.
[Dan Macnish]’s latest project, Draw This, turns reality into absurdity. It’s a Raspberry Pi-based instant camera that trades whatever passed in front of the lens for a cartoon version of same. Draw This uses neural networks to ID the objects in the frame, and then draws upon thousands of images from Google’s Quick, Draw! dataset to provide a loose interpretation via thermal printer. Seems to us like the perfect camera to take to DEFCON (or any other part of Las Vegas).
If you have a Raspi3, a v2 camera, and a thermal printer, you can make your own crowd-sourced, cartoonified memories using the code in [Dan]’s repo. Still into recording reality? You can use Pi cameras to see in the dark or even explore a body of water.
12 thoughts on “A Cartoon-ifying Camera For Instant Absurdism
Leave a Reply to fm`Cancel reply
