Rediffusion Television: Early Cable TV Delivered Like Telephone
Recently I spent an enjoyable weekend in Canterbury, staying in my friend’s flat with a superb view across the rooftops to the city’s mediaeval cathedral. Bleary-eyed and in search of a coffee on the Sunday morning, my attention was immediately drawn to one of her abode’s original built-in features. There on the wall in the corner of the room was a mysterious switch.
Housed on a standard-sized British electrical fascia was a 12-position rotary switch, marked with letters A through L. An unexpected thing to see in the 21st century and one probably unfamiliar to most people under about 40, I’d found something I’d not seen since my university days in the early 1990s: a Rediffusion selector switch.
If you have cable TV, there is probably a co-axial cable coming into your home. It is likely to carry a VHF signal, either a series of traditional analogue channels or a set of digital multiplexes. “Cable ready” analogue TVs had wideband VHF tuners to allow the channels to be viewed, and on encrypted systems there would have been a set-top box with its own analogue tuner and decoder circuitry.
Your digital cable TV set-top box will do a similar thing, giving you the channels you have subscribed to as it decodes the multiplex. At the dawn of television transmission though, none of this would have been possible. Co-axial cable was expensive and not particularly high quality, and transistorised wideband VHF tuners were still a very long way away. Engineers designing the earliest cable TV systems were left with the technology of the day derived from that of the telephone networks, and in Britain at least that manifested itself in the Rediffusion system whose relics I’d found.
Cable For The ’40s
Inside a Rediffusion cabinet in Canterbury. Adam Sampson, (CC BY 3.0).
So imagine for a minute that it’s the late 1940s, and a network of VHF TV transmitters (in the lower VHF band from about 50 to 80 MHz) is being put in place across the nation to carry the single BBC 405-line TV channel in glorious monochrome. Some areas of the country can’t pick up an acceptable signal, because of annoying geography. Entire cities will miss the chance to see important events, so they are fitted with a network of twisted pair cables in a tree topology of multiple nodes with repeater boxes on street corners.
Of course, you can’t take a bundle of twisted pairs and send baseband video down them over any significant distance, so the video had to be modulated onto something. There were tubes available that could do VHF and even UHF in the post-war period, but the twisted-pair network only had a bandwidth somewhere in the HF.
The solution was to vestigial-sideband modulate video for distribution onto an HF carrier. When a second channel arrive in the mid-1950s, different carrier frequencies and opposite sidebands were used to minimise crosstalk for adjacent pairs. For the two-channel 405-line system the frequencies were 4·95 Mhz and 8·45 MHz. Crosstalk due to the overlapping sidebands remained at a point that couldn’t be seen on the customer set as long as the cable system had no mismatches. In the home, instead of a broadcast TV set the subscriber had a Rediffusion-branded TV with a built-in demodulator.
At the close of the 1960s the country moved from the 405-line system to a 625-line PAL colour standard, and the Rediffusion systems were upgraded to cope. The selector switch I’d found in my friend’s flat dated from this era, by now the cabling to each house possessed multiple twisted pairs for an anticipated multi-channel future. Slightly different carrier frequencies were used, and since most Rediffusion customers at the time also rented a TV set from the company, the viewing equipment was also upgraded.
The Decline and Fall of the Rediffusion Empire
So through the 1970s and early 1980s there were some British cities that still had a 1950s cable TV system. By now the conditions that had given rise to it no longer existed, as the new UHF transmission network had many more channels and thus far fewer low signal areas. The multichannel future was seen as coming from satellite broadcasting instead, and after some ownership changes and mergers the company ceased trading some time at the end of the 1980s.
In most cases the network was then simply abandoned, as was the case in Canterbury, but in a few cities it remained in use for a few more years before shutting down. The Rediffusion boxes I’d seen as a 1990s student in Hull were operated by a local company and carried some of the Sky satellite channels, and because by then the antiquated technology was comparatively open compared to encrypted satellite channels there was a lively hacking scene. The former Rediffusion regional headquarters was a derelict shell on the main road out of town, and there were technical documents aplenty ripe for the taking.
Potted transformers inside a Canterbury switch box. Adam Sampson, (CC BY 3.0).
Drawing on my memories from the time as well as referring to the HackHull site, both the “official” set-top box and the clones were simply upconverters that shifted the HF carrier from the twisted pair up into the range that a standard TV could tune into. A simple enough circuit with a single transistor could do the job, and as I remember it could even be done with a modified mechanical TV tuner. There are sites on the web that incorrectly describe the distribution as being at VHF frequencies and suggest the use of a VHF upconverter: these would work, but by an unintended means. In those devices there is an oscillator somewhere in the VHF range that would produce a harmonic that your UHF TV set could tune into, so when mixed with the HF Rediffusion signal it would still produce a picture on your TV.  Subscriber management was simply a case of disconnecting a house at the junction box, and I remember in particular that my student house was not one of the lucky ones that had been left connected by accident.
Years later, all that remains of the Rediffusion networks are a few relics. Switch boxes in older houses and apartments, a few manhole covers, and very occasionally an intact distribution hub. Cable TV in the form of co-axial cable came to most UK cities in the 1990s, but even that is being displaced by internet streaming over fibre and has instead become primarily an internet delivery medium in its own right. The idea that there were once miles of multi-way twisted pair cables snaking around the neighbourhoods simply to deliver a pair of low-ish definition black-and-white TV channels seems bizarre in 2018, but for its time it was at the absolute bleeding edge. If you happen to live in a Rediffusion town, keep an eye out. There have to be some artifacts of the network still remaining.
64 thoughts on “Rediffusion Television: Early Cable TV Delivered Like Telephone
      1. Possibly a future topic for this series, but when we built our new house out in the country in Iowa twenty years ago, we noticed that a lot of our neighbors had parabolic antennas pointing in the same direction. When we installed a new tv in our bedroom and did a scan for channels, a bunch of interesting UHF channels appeared, including one that was HBO!
        A little research on the internet revealed the service known oxymoronically as Wireless Cable…..a tower in a little town about 30 miles away was providing Cable TV over microwave (the parabolic antennas) and some UHF frequencies. Channel assignment seemed to change frequently, but at times we could get premium channels like HBO for free.
    1. Hi, I’m from the UK, these switch boxes were are cable TV and us children were the control 🤣 I can remember only having 3 TV channels and one of those was the radio x
  1. Very cool. In another 20 years, they’ll be doing this kind of archaeology on the POTS network. It’s already falling into disrepair where I live, as the telco abandons it (no future and no profit in maintaining a copper network when everyone wants FTTH).
    This sounds like a very early version of DSL (though without the awesomely cool dynamically adaptive multi-carrier scheme)
  2. As a kid in the late 1950’s through 1960’s. our Lincoln council house had piped radio… the ‘receivers’ were basically a rather simple demodulator+amp with a big speaker and a lot of empty space (yep, opened it up to have a peek). The receiver was attached to a plastic box via a (then) standard 2 pin mains plug and the station was selected by a multiway switch on top. After so many years I can’t remember how many channels there were, it was moot anyway beause it was always tuned to the BBC Home service for Two Way Family Faviourites.
    1. A similar system called “draadomroep” (literally: wirebroadcast) or radio distribution was widely used in the Netherlands from the 1920’s up to 1975. It offered a selection of four(!) stations and a volume control knob. Sound quality was excellent but the limited choice of stations doomed the system.
      1. We definitely had more than four, though I cannot remember anything other than BBC Home Service and (very occasionally) BBC Light Service. I have no doubt that I tried all the positions, but more than 50 years on I really can’t remember what was there :-) Now you mention it, there was a volume knob on the side of the wooden box holding the speaker (quite large) and the remainder of the circuit (which was a tag strip mounted on the back of the speaker). Happy days.
      2. I was going to say that :)
        The system was run by the Dutch nationalized mail and telephone company PTT (now known as KPN).
        For a long time I had a Philips tube radio that has belonged to my parents and had a “radio distri” input and source selector. When the radio receiver stopped working, I connected the input to the headphone output of a small transistor radio and that way I could still record radio shows on my little cassette recorder. Good times.
        By the way I saw the actual outlet for the “draadomroep” only once. It was made out of brown bakelite and had a switch to choose from the 4 programs. Note, in the days that the network was active. There were only two national Dutch radio stations, so it was definitely prepared for the future! :)
    2. Sorry, somewhat OT but geek relevant. In the 60’s, the most awesome UK import to the USA were the progeny of Gerry/Slyvia Anderson. I remember growing up on “The Thunderbirds”, also later in the 70’s “UFO” (SHADO), SkyDiver was brilliant (engineeringly implausible, but still kick-ass!).
    3. Think that was actually on the Light Programme, midday Sundays. 1500 metres, long wave! Used to “listen-in” on a rather elderly valve radio with a long-wire aerial. Nice mellow tone, y’ know!
  3. At some point along the line one do start to wonder if they could have just switched to coax…
    Since the coax probably would be better then the twisted pair. After all, they didn’t seem to have any problem adding more twisted pairs, and fiddling around with everything else. Seems more like their failure were down to not taking the step to something less fiddly.
    Even though a twisted pair of wires and some good differential signaling can technically give 0.5 Gb/s with ease for fairly good distances (this being standard Gigabit Ethernet and yes the full 1 Gb/s is on two pairs) and even then we have 12 Gb/s per twisted pair in an HDMI cable. Although, an hdmi cable with is individually shielded twisted pairs is kinda “advanced”. (Could probably have been manufactured with ease and at a cheap price back in the 60’s… Since twisting wires and wrapping foil around them isn’t hard…)
    Though, biggest downside with all electrical networks for high bandwidths is the high signal loss for a given distance. While an optical fiber generally has far less loss over the same distance. Fibers though typically have far higher losses in connectors, not to mention other connector related issues that electrical standards doesn’t have to nearly the same degree. And this being why short distance communication (sub 100 meters) most likely will remain electrical for years to come. (Although, there is always those people that use fiber for the pure reason that it surely must be better, “it is freaking light after all!”…)
    1. “Since the coax probably would be better then the twisted pair.”
      While coax could handle higher rates than twisted pair, Cat5e TP is handling far higher data traffic than thinNet ever did. Maybe it is because of the crappy coax that was out there, and the likely occurrence of crimping a lousy coax connector. Or maybe because ThinNet wasn’t point to point, it could be mis-routed or under/over terminated, oh yeah, let’s not forget packet collisions.
  4. “The idea that there were once miles of multi-way twisted pair cables snaking around the neighborhoods simply to deliver a pair of low-ish definition black-and-white TV channels seems bizarre in 2018, but for its time it was at the absolute bleeding edge. ”
    If the internet is a series of “tubes” then everyone would be getting their media via pneumatic tube transport (PTT).
        1. I think they meant the electrical kind of tube.
          But a vacuum driven pneumatic system is also a thing that works. Downside here is that the highest differential pressure would only reach 1 atmosphere. Unless one uses both pneumatic pressure and vacuum, then with the same tube we should be able to reach even larger differential pressures. (Unless our tube has horrid tensile strength.)
      1. I always assumed Sen. Stevens was referring to pneumatic tubes. And I’m an EE!
        Funny, how the “series of tubes” has become part of our vocabulary. When The Internet is slow, or down, “the tubes are clogged”. Planned network outage is “tube cleaning”, etc. Well, maybe it’s only at my house that you’ll hear this.
  5. I used to holiday in a village in Scotland that due to geography had to have its TV provided in pretty much this way – the village was in the shadow of one of the taller mountains in the area, so while the far side of the loch a few miles away had line of sight on a transmitter mast, the village itself was in the shadow. I believe they ended up with this until the analogue signal was turned off in 2012 – no idea what they do now.
    The real fun was when Sky started service, lots of people got excited that they’d finally get decent TV.
    Turns out that the same mountain causing the problems with the terrestrial TV transmitter had an outcropping *directly* in the line of sight you needed to get transmissions from the Astra satellite. I did hear that the manager at a local activity center had told his hill team to “take a few of the lads and 5lb of gelignite and have an accident somewhere in the direction of that bloody peak”.
    BSB wasn’t any better – that part of Scotland simply couldn’t get the coverage from the tiny Squarials that the Marcopolo based system was using.
  6. A friend of mine (now dead) designed and installed this system in Burnley and Newcastle and maybe other places, I suppose it really was his life’s work.
    In 1994 I took a head end and several consumer end units and used them to demonstrate video over power lines at a conference in Paris. I still have the gear and it was a pretty impressive demonstration. At that time it was still working in Burnley though they had moved to a very small building for the head end and just used a consumer satellite dish for the source, some arrangement with BskyB and Sky.
    In Burnley they needed to get it to the next town (Padiham) about four miles away without laying cable so they took a leased line from BT and used it for HF, this was before bandwidth limiters were fitted to the telephone lines. It worked well for a long time until one day it didn’t, that was when they installed the filters at BT.
    1. I rolled out quite a lot of HDSL using BTs EPS8 and EPS9 “alarm wires” which were originally just naked pairs looped at the exchange distribution frame and connected to another set. Could run them at 2MB/s all day every day until, as you say, BT noticed.
      Specifically, they realised that the same wires they were about to start selling ADSL over could be used by other people the same way and “Conditioned” the alarm wires – done by sticking a honking great inductor in place of the DF patch cable and reducing the effective bitrate on one of those lines from “How fast can you wiggle the electrons” to no more than 1200bps, with some horrible ringing artefacts if you tried to go much beyond that.. The lines still worked for their intended purpose of allowing you to close a switch and have a circuit complete setting off a trigger on a remote alarm monitor, but no more than that.
      BT in the late 90s were a bit of a nightmare – that the sudden uptake in internet connectivty hugely increased the number of landlines, and BT being BT rather than running copper would put the infamous DACS TDMA pairgain boxes in the lines to split off another line – your nice V34 at 33600 suddenly drops to 9600 because your line’s suddenly gone from being an analogue circuit to a digital circuit quantised for minimal speech frequencies and fax machines at a “guaranteed” rate of 2400bps.
      On the other hand, they did some cool stuff – one connected city trial (In Swindon I think) had set top boxes which were basically Macintosh motherboards with some exotic modem installed (I think 10broad36 – go look it up – it was a fairly cool tech in its day)
      1. I still have one last EPS8 in my network, can’t get FTTC to the site yet (if ever)… It’s currently running at 6.5Mbps (ish) which is adequate for the requirement :-)
  7. I remember stumbling across the HackHull site ages ago and being puzzled by how it described I could open the box on the side of my house and rearrange some wires and get free TV. Opening the box just revealed the traps that were used to provide the pay channels, and I was quite bewildered until I realized the site was in England :-P (The cable provider injected a garbage signal that I believe was 4.5mhz downband from the actual TV signal, that the AFC in the TV tuner would latch onto, so if you tuned to HBO for example you’d get a “beep beep beep” over the audio and a herringbone pattern over the video signal, rather than the suppressed sync other cable systems used. One could use a TV with manual fine tuning and get a watchable signal but if you paid for the channel they just installed a notch filter that filtered the garbage signal out. I remember one of the neighbors moved and gave me her traps and I had all the premium channels until AT&T bought out TCI and they changed the system in the early 2000s.)
  8. People still refer to programmes being “on the pipe” or “on the relay”.
    They could only do it because in the densely packed terraced housing owner occupiers were rare so when they nailed the wire to your wall just under the troffin (gutter) people didn’t complain but towards the end people would not put up with it so large parts of the network were rendered useless because someone wanted to paint their front wall and just ripped it off leaving it dangling in the road.
  9. As soon as I saw Redifusion mentioned in the email I figured Jenny would be the author. They were a very British company, if you look around the sources on the net archiving this stuff you’ll find all about their dev and repair labs and other sites … I believe Edinburgh /Hullwas another ?!?! Either way it shows you what you can do with some twisted pair
    http://www.rediffusion.info/FHAusten/
    1. I worked for Rediffusion Industrial Services in the early seventies at the Edinburgh Branch. As far as I know there was no Rediffusion Town System in Edinburgh. Although Livingston New Town had British Relay Cable TV in the Scottish Borders BR provided a service because of poor reception. Our job with RIS was to service cable tv systems in mainly British Transport Hotels such as the Caledonian and North British Hotels in Edinburgh as well as all the others such Turnberry (now Trumped) as well CCTV systems, Internal Telephone & Intercom Systems and Reditune background music systems. The cable TV systems were exactly the same as used by Rediffusion for public cable TV networks. We were all trained at Rediffusions Engineering Training School in Poulton le Fylde.
  10. I grew up on a newly built council estate that had redifusion we had 4 tv channels bbc 1 bbc2 ITV and tyne tees tv . plus several national and local radio. my parents also bought me a video console from redifusion that had an adapter. a box wiht a large male din type plug and socket. this plugged in to tv and the cable from the wall switch plugged in to this. the console then plugged in to the side of this via a 1/4″ jack plug.
    many years later i moved to a house which still had the redifusion oved cable attached. the whole street did. with the system now defunk. i tapped in to the cable to use it as a long wire for short wave listening. dont know the actual length. but i used to get some dam good signals
  11. I was part of HackHull back in the 90s when I was also at University. I remember the rediffusion building (including one of the times it caught fire). I know the authors of the article on the HackHull website and can put you in contact if required.
  12. my dad was a rediffusion engineer, as a kid i got to play with all sorts of cool stuff, the first radio i built was using a signal amplifier box, it had a 64C valve, i used the plastic box upside down to mount the components and a socket to change coils for different vhf bands.
  13. Ahh…hacking cable TV: an activity dear to my heart.
    In the 80’s, we had cable using addressable Jerrold 450 converters, and one of the channels always had an annoying buzz-saw noise on it (which I recognized as data). Hmmm, I thought to myself, wonder what they’re transmitting?
    A little research revealed that the channel in question was in the middle of the FM band. A stripped down clock radio provided the means to see the data, and a 6800 D2 kit (think: KIM-1 but for the 6800) allowed me to look at the bits.
    Turned out, what was being transmitted was box addresses and channel permission bits (a “1” gave the box access to that channel, a “0” told the box not to display it) — after quite a bit of noodliing, I was able to get all the channels on my box, simply by replacing the address PROM with a circuit board with switches to set the box address to anything I wanted.
    Good times. After proving it worked, I lost interest.
    Along the way, I discovered the varactor tuner used in the box made a fairly good poor man’s spectrum analyzer, when combined with the a sawtooth output of a signal generator and an oscilloscope.
    1. Back in the 80’s, I found a much easier hack for the Gerrold boxes. ;) A 74123 dual one-shot chip and a few support components. I bypassed the computer completely, and just used the analog “gated sync” signal that was available on one of the wires going into the computer… and they had a 21V shaped pulse output, which restored the sync on subscribed channels. My little circuit just restored the pulses, and fed them into that 21V pule input. It worked amazingly well! :) The drawback with some boxes, was that it required a disconnect switch. Other box3es that had an unused “A/B Cable select” function… lit an LED on the face, and nothing else. I was able to tap into the LED signal, filter it (it was pulsed) and used that to turn my circuit on/off with one of the RESET inputs of the 74123. :) Then, you could turn the “descrambler” on/off with the remote control. :) That was the “Deluxe” version. ;) That technology is now just about as outdated as the Rediffusion system being discussed here. :) For me, as a teenager, coming up with such a functional descrabler was quite the accomplishment! I only made maybe 6 or 7, total… getting my hands on the boxes was the hard part! ;) Since my Dad was the superintendent of a 58 unit apart building, now and then, someone moved out and left the box behind! :) That was how I acquired ’em. ;) Yeah… fun times for a Geek kid! ;)
  14. I live on the vast flat plains of North America and radio based TV was easy to distribute EVERYWHERE in that area. (almost no small villiages lost down in a deep valley) Consequently such a system like this would be totally unnecessary here, but it just goes to show how different situations demand different solutions. Britain’s not so level land and higher population density would make wires like this more practical back when they were in use. Having watched way to many episodes of “Last Of the Summer Wine”, I often wonder if any part of Britain is level. :-) It seems like the characters are always walking/riding up or down a steep hill. Of course “steep” is relative. In my region its not uncommon for the water to not be sure which way to flow when it rains a lot. Eventually it figures it out, but most of it just sinks into the ground until the ground level and the water table find unity. :-)
    1. And yes, for you Rick and Morty fans out there, we have found “The Perfect Level” on multiple occasions here on the plains of North America. :-) (One of the reasons why many of us wouldn’t even consider leaving) :-)
    2. foxpup, all of “Last Of the Summer Wine” is set in Yorkshire, which is very hilly. Most of those hills are covered in tea plantations, which is where we get ‘Yorkshire Tea’ from. If you want to ingratiate yourself with those folk you will need to acquire a whippet and a flat cap.
      The hilliest part of England is an area known as East Anglia, where there are many active mountaineering groups.
      (some of the above is not necessarily true …)
  15. Rediffusion was an extraordinary engineering company. They started out in the 20’s distributing radio and TV signals through their own wired relay networks- FIRST in the World. They branched out into making, renting, and selling radios, and subsequently TV’s.
    In 1950 they introduce the world’s FIRST cable TV network in the South East (using twisted pair cables rather than coax), and became a broadcaster. They even expanded into Flight Simulators, and Computers.
    T
    hey were the FIRST to pioneer online shopping in the ‘70’s (before the Internet was even thought of). Their system connected a modified domestic TV to a transactional computer via a telephone line. ‘Videotext’.
    Like many British pioneering companies, they were gobbled up by large corporate entities, with their culture and entrepreneurial spirit destroyed.
  16. In the early 1970’s I worked for a UK company that supplied equipment to Rediffusion for cable TV distribution. It consisted of a PCB with 12 reed switches mounted in a circle that were actuated by a magnet on a metal arm that was attached to a stepper motor in the centre of the board. Every time the motor was energised the arm would turn such that the next reed switch was closed by the magnet & the appropriate TV or radio channel was selected. There would have been one PCB per subscriber but I think it would be mounted in a box on the side of the road, similar to those for cable TV nowadays. As it happens there is a Rediffusion manhole cover only 50 metres from my home.
  17. This is so nostalgic cos I used to live up the road from one of the depots in St Leonard’s on sea when I was a little girl. Of course we had Rediffusion so seeing the selector switch bought back so many memories. In fact, I would love to own one so I can put on the wall by the window! Can anyone tell me where I can buy one of these switches? I quite keen.
  18. Thanks for the read. I moved into my property in hull, the lady who lived in the house before me had lived in the property since it was built in the 70’s. When I moved in 4 years ago, I noticed the Rediffusion switch on my wall, but I was born in 1990 and grew in Germany so I didn’t really know what it was. So it was interesting to read this. I am keeping it up on my wall as I think it looks good and it’s a bit of history in my house. Again thank you for the information
  19. Before I was 6 my parents lived in St Marks Vicarage, Mansfield (until 1967) and they were not wanting television in the house, especially as it did not a separate television room. They had a rediffusion system which played all the radio stations, from the BBC and maybe others but they preferred listening to TV without a set, since they said that the News was the only thing worth watching (& the Queens Speech) and they usually had BBC2 on when there was classical music or university challenge. They were very much opposed to anything from ITV. In 1967 we moved to a rectotory the size of a minor stately home, and there they started renting b&w tvs (good for the moon landings, but colour had to wait until my father was promoted to cathedral canon in 1972 when a new rented Mitsubishi colour TV and a TV in my bedroom made it all seem worthwhile. I never heard of anyone else “listening” to TV. I was the only child at school 1965-67 whose favourite TV programme was the News. I also listened to Radio moscow on SW to help me sleep
  20. Cable TV is far from over in the UK, just because there is a craze for streaming services doesn’t mean that’s the future, its a fad. Virgin Media Cable TV is good because it bundles a wide range of Live channels with TV on demand and also streaming services all in one box/one place.
    If you do not have a Virgin Cable box or Sky box, then its very inconvenient to have multiple streaming services and also works out expensive.
    The only reason some streaming services are popular is because some specific content is exclusive to the streaming service, once Cable and satellite channels start buying this content and making it exclusive to their own channels like Sky Atlantic, there is little need to subscribe to streaming services.
    Some streaming services also do not update their content often enough, so once you’ve binged watched all the stiff you like,.its time to cancel.
    Sky Cinema channels show all the films on Live channels but the entire library is available On demand through Virgin Cable and Sky satellite TV boxes, in fact some films that are still in Cinemas are sometimes also available through these channels whereas they become available on streaming services years later.
    The amount of Virgin Cable subscribers has stayed around just over 4 million for many years and hasn’t changed much but you are right in saying Cable Internet is more successful than Cable TV.
    But for me its Time to hang up on Netflix and Disney plus!
  21. All very Interesting but how does one remove these twisted cables from the gable wall of your property? The cables stretch across the road to another house but they are affecting the structural integrity of my gable wall ☹️
  22. I grew up in Hong Kong where there was a Rediffusion Cable TV service. Many hotels also had the Rediffusion audio service. I remember measuring the socket in our home that we plugged the Redifussion box into and the pins were at mains voltage so it took a lot of power to transmit the signal. This was at a time where there was also the RTV service. For many years there was our only TV station until the UHF TVB channels started broacasting.|
    When you walk the streets of Hong Kong you can still see the square RTV manhole covers. These relics of the past continue to bring me joy.
  23. I lived in Thanet, Kent in the 1960s where we hired a Rediffusion television set together with its cable service delivered through the A, B, C…. Box on the wall. As others have said, radio didn’t require the tv to be turned on as such. For television channels as well as BBC 1 (405 lines) and BBC2 (625 lines) we had both Southern Television (the whole week) plus Rediffusion London (weekdays) and ATV London (weekends), that became Thames and London Weekend respectively in 1968. My grandmother who lived with us preferred the latter because she liked watching Thames Callan, which she didn’t appreciate was also carried by Southern.
    We moved hose in the 1970s and went to an aerial that lost us the London region and hated tedious Southern.
  24. Not too sure why, but when I was a mere lad (late fifties into sixties), Rediffusion in my area (Maidstone in Kent) had a structure next to a local park with several large dishes attached. As it was very early days for satellites, I often wondered what they were actually receiving. As an aside, their cable system (bits of which are still visible locally on some houses, with their substantial anchoring gubbins) seemed OK when we had B/W but when colour came along, pictures suffered with perpetual patterning, which always seemed worse in the evenings.
Leave a Reply to ThanksforallthefishCancel reply
