Professional or amateur, doing things the hard way doesn’t always make for better results. Take photography as an example. Once upon a time, the success or failure of what happened during the instant that the camera’s shutter was open was only known hours or days later after processing the film. Ruin the shot with bad exposure or suboptimal composition? Too bad. Miss a once-in-a-lifetime moment as a result? Ouch.
Once instant photography came along, pros were quick to adopt it as a quick and dirty way to check everything before committing the shot to higher-quality film. Camera manufacturers made special instant film cartridges that could be swapped for roll film, and charged through the teeth for them. Unwilling to shell out big bucks, [Isaac Blankensmith] hacked his own instant film back for his Hasselblad medium-format camera. The unlucky donor camera was a Fujifilm Instax, a camera that uses film packs similar to those used by Polaroid and Kodak instant cameras from the 70s and 80s. Several of these cameras were dissected – carefully; those flash capacitors pack a wallop – and stripped down to the essential film-handling bits. An adapter was fabricated from laser-cut acrylic to mount the film back to the Hasselblad, with care taken to match the original focal plane. The shots are surprisingly good; despite a minor light leak from the adapter, they’re fine for the purpose. The best part: the whole build took just 48 hours from conception to first shots.
Speaking of Polaroid, we’ve featured quite a few hacks of Edwin Land’s venerable cameras over the year. From replacing the film with a printer to an upgrade to 35-mm film, instant cameras in general and Polaroids in particular seem to have quite a following among hackers.
Thanks for tipping us off, [macsimski].
i’ve been nailed by those flash caps before for a second it feels just like 110 that i’ve also been hit with
At first I read “mailed” and I thought someone mailed it to you as a joke, and I thought to myself “I’m pretty sure that’s a crime.” But then I re-read it, realized I am dumb, and posted this anyway. Mostly because it reminded me of a time in auto shop class in high school when somebody would say “think fast!” and toss another person a condenser. Charged, of course. Much fun was had.
my dad and his friends used to do that to each other
In my HS electronics class we would charge up some big 600v 100uF caps and poke people with ’em. The first project the teacher gave people was making a ‘shock box’ where you hand someone a box “innocently” covered with strips of aluminum foil and give ’em a shock, courtesy of a batter, a cap and a jiggle switch made from copper wire and a nut.
I laboriously built mine into a soda can which only worked intermittently, and one genius decided that hey, an automotive coil would fit in his! That one got confiscated right away…
under 100uf it’s not a crime :)
now that’s a hack and a half!
I’m not even sure you could BUY a useful instant back for a Hasselblad anymore. Most of those were made decades ago for Polaroid film. So this is a bit more than a hack and possibly the only way to return this useful capability to the system without buying reproduction Polaroid packs.
Since the Impossible Project is now Polaroid Originals after buying the Polaroid IP and brand, they’re now making authentic Polaroid packs instead of reproductions!
