Hexagonal Lamp Is A Stylish Application Of Plywood
Lamps are useful things, and can be a great way to add style and lighting options to a room. Where overhead lights have to provide enough illumination for all manner of tasks, a subtle table lamp can add a nice moody glow to a room when it’s time to kick back and relax. Oftentimes, a stylish lamp can be let down by having a run of the mill plastic switch hanging off the power lead, but it doesn’t always have to be the case. [Emiel] designed this hexagonal lamp with a hidden switch, which works remarkably well.
[Emiel] starts by laying out hexagonal paper templates on plywood and perspex sheet. The plywood is cut on the bandsaw, while the interior cuts on the perspex are made on a scroll saw to avoid unsightly cut entry lines. The outer half of the lamp slides up and down on a pair of steel rods. Springs hold the outer half up, and it can be pressed down to activate a switch inside to turn the lamp on and off.
The build has a clean and attractive aesthetic, with the LEDs hidden inside, glowing through the perspex slices built into the body. It looks like something you’d find in the rooms at the Tranquility Base Hotel & Casino. If regular lamps aren’t enough for you, however, you could always consider building something interactive. Video after the break.
10 thoughts on “Hexagonal Lamp Is A Stylish Application Of Plywood
        1. Many years ago…
          A random parcel turned up for previous tennant – they had left under a cloud of huge debt and were an MLM
          Inside were two USB drives (when these were expensive)
          I loaded them on a disposable machine and they were jammed full of this MLM crap
          Once formatted (DoD wipe) they made rather excellent portable storage
          Not sure how these guys make any money !!
          1. Those MLM representants DON’T make any money. They are scammed into buying some cheap crap marketed as high quality products for selling. Only those products are crap which nobody normal would buy. So they go from home to home trying to sell something nobody want’s to buy, but they already bought that product. Those who sold them to the lowest tier are really those who made profit. It’s almost like piramid scheme. I’ve seen this several times. Only people gullible enough go for this.
  1. Nice and stylish build. I think i will build one myself. Thanks! Yet it seems to be rather ineffective. So many LEDs for such a little amount of light, that reaches the outside. Maybe an LED Bulb would be a better choice.
    1. I was thinking the same thing re: inefficiency. Maybe having a reflective internal surface would make it brighter? Also, I didn’t see any ways for heat to escape – how much heat are those LEDs throwing off?
Leave a Reply to icanhazaddCancel reply
