Play Tetris On A Transistor Tester, Because Why Not?
[Robson] had been using the same multimeter since he was 15. It wasn’t a typical multimeter, either. He had programmed it to also play the Google Chrome jumping dinosaur game, and also used it as a badge at various conferences. But with all that abuse, the ribbon cable broke and he set about on other projects. Like this transistor tester that was just asking to have Tetris programmed onto its tiny screen.
The transistor tester is a GM328A made for various transistor testing applications, but is also an LCR meter. [Robson]’s old meter didn’t even test for capacitance but he was able to get many years of use out of that one, so this device should serve him even better. Once it was delivered he set about adding more features, namely Tetris. It’s based on an ATmega chip, which quite easy to work with (it’s the same chip as you’ll find in the Arduino Uno but [Robson’s] gone the Makefile route instead of spinning up that IDE). Not only did he add more features, but he also found a mistake in the frequency counter circuitry that he fixed on his own through the course of the project.
If you’ve always thought that the lack of games on your multimeter was a total deal breaker, this project is worth a read. Even if you just have a random device lying around that happens to be based on an ATmega chip of some sort, this is a good primer of getting that device to do other things as well. This situation is a fairly common one to be in, too.
4 thoughts on “Play Tetris On A Transistor Tester, Because Why Not?
  1. Robson Courto, that’s really close to the name of a character in Ian McDonald’s Luna trilogy. There’s a Robson Corta in those books.
  2. “While studying the board, I came across something really strange. A via on the board was not connected to anything. By the looks, it seemed that the trace coming from PD4 should be connected to the frequency measurement circuit. Later, I looked at Markus’ firmware and PD4 was indeed the pin used for frequency measurement there.”
    This also appears to be an error on my GM328A. Nice catch!
  3. “hire me”
    ROFLOL – a young EE grad brings that to me in an interview… I would almost hire them on the spot.
Leave a Reply to Morgan ThompsonCancel reply
