Flywheel Stores Energy To Power An Airplane – Eventually
Question: Can a flywheel store enough energy to power an airplane? Answer: Yes it can, for certain values of “flywheel” and “airplane.”
About the only person we can think of who would even attempt to build a flywheel-powered airplane is [Tom Stanton]. He’s a great one for off-the-wall ideas that often pay off, like his Coandă effect hovercraft, as well as for ideas that never got far off the ground, or suddenly met it again. For most of the video below, it seems like his flywheel-powered plane is destined to stay firmly in the last category, and indeed, the idea of a massive flywheel taking flight seems counterintuitive. But [Tom] reminds us that since the kinetic energy stored by a flywheel increases as the square of angular velocity, how fast it’s turning is more important than how massive it is. The composite carbon fiber and aluminum flywheel is geared to the propeller of a minimal airplane through 3D-printed bevel gears, and is spun up with an external BLDC motor.
Sadly, the plane never made it very far, no matter how much weight was trimmed. But [Tom] was able to snatch victory from the jaws of defeat by making the propeller the flywheel – he printed a ring connecting the blades of the prop and devised a freewheel clutch to couple it to the motor. The flywheel prop stored enough energy to complete a few respectable flights, as well as suffer a few satisfyingly spectacular disintegrations.
As always, hats off to [Tom] for not being bashful about sharing his failures so we can all learn, and for the persistence to make his ideas take flight.
7 thoughts on “Flywheel Stores Energy To Power An Airplane – Eventually
  1. i think the real problem here is the you are trying to fly with a gyroscope on your plane. any friction at the bearing is going to result in an equal and opposite pitching moment. counteracting this at the control surfaces is going to cause drag that will sap the aircraft’s velocity. two flywheels spinning in opposite direction would remove these losses.
  2. Seal the flywheels in a small vacuum enclosure, and make it flywheel-electric-propeller motor.
    F1 Flybrid tech would be a great place to research!
  3. +10 for video that launches right into the topic with absolutely none of the “As I’ll explain later, what we’re gonna do is we’re gonna….’
