Getting a child’s attention can be difficult at the best of times. Add deafness into the picture, and it’s harder again. [Jake]’s daughter recently had to go without her cochlear implants, raising this issue. Naturally, he whipped up some hardware to solve the problem.
[Jake]’s solution was to devise a vibrating wristband that could be used to get his daughter’s attention. An Adafruit Trinket M0 is used to vibrate a pager motor, using a DRV2605 motor driver. This is paired with a Tile Bluetooth device, allowing the unit to interface with Google Assistant. This allows [Jake] to get his daughter’s attention with a simple voice command to a smartphone, tablet or smart speaker.
While [Jake]’s daughter will regain her cochlear implants soon, they do have limitations as far as hearing distant sounds and working in high-noise environments. It’s likely that this little gadget will prove useful well into the future, and could serve others well, too. Wearable notification devices are growing more popular; this OLED ring is a particularly good example. Video after the break.
Just a mind shock?
China’s got ya covered!
https://www.amazon.ca/Petrainer-Rechargeable-Waterproof-Vibration-Electronic/dp/B00W6Y3I3O/ref=asc_df_B00W6Y3I3O/?tag=googleshopc0c-20&linkCode=df0&hvadid=292980564438&hvpos=&hvnetw=g&hvrand=6167079559906523966&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061009&hvtargid=pla-401345822589&psc=1
FYI, you can shorten those Amazon links:
If you shorten the link like that, then we can’t all track you ;)
Was there anything embarrassing in the recently viewed items?
And besides I search for dildos and butt lube on a different computer!
WHY IS THERE NO ERASE COMMENT OPTION!!!!
Exactly! :)
Cool project! I know a lot of hearing capable/listening impaired people that need this where I work.
