Less Rock, More Roll: A MIDI Barrel Piano
Strolling around a park, pedestrian zone, or tourist area in any bigger city is rarely complete without encountering the sound of a barrel organ — the perfect instrument if arm stamina and steady rotation speed are your kind of musical skills. Its less-encountered cousin, and predecessor of self-playing pianos, is the barrel piano, which follows the same playing principle: a hand-operated crank rotates a barrel, and either pins located on that barrel, or punched paper rolls encode the strings it should pluck in order to play its programmed song. [gabbapeople] thought optocouplers would be the perfect alternative here, and built a MIDI barrel piano with them.
Keeping the classic, hand-operated wheel-cranking, a 3D-printed gear mechanism rolls a paper sheet over a plexiglas fixture, but instead of having holes punched into it, [gabbapeople]’s piano has simple markings printed on them. Those markings are read by a set of Octoliner modules mounted next to each other, connected to an Arduino. The Octoliner itself has eight pairs of IR LEDs and phototransistors arranged in a row, and is normally used to build line-following robots, so reading note markings is certainly a clever alternative use for it.
Each LED/transistor pair represents a dedicated note, and to prevent false positives from neighboring lines, [gabbapeople] 3D printed little collars to isolate each of the pairs. Once the signals are read by the Arduino, they’re turned into MIDI messages to send via USB to a computer running any type of software synthesizer. And if your hands do get tired, you can also crank it with a power drill, as shown in the video after the break, along with a few playback demonstrations.
It’s always fun to see a modern twist added to old-school instruments, especially the ones that aren’t your typical MIDI controllers, like a harp, a full-scale church organ, or of course the magnificently named hurdy-gurdy. And for more of [gabbapeople]’s work, check out his split-flip weather display.
5 thoughts on “Less Rock, More Roll: A MIDI Barrel Piano
  1. funny they don’t mention the player piano, of what this is a electronic copy. especially as the barrel piano cannot hold long notes well.
    1. I couldn’t decide between “player piano” and “self-playing piano”, and after a coin toss went for the latter. But yes, player piano would be a more specific successor.
      1. A story about player piano history would be an interesting read in retrotechular as it works pneumatic with very beautiful mechanics involved.
  2. That roll is wide enough for Conlon Nancarrow’s biggest works for two 88 note player pianos. That’s some parallel digital interface for sure! That was with a much narrow track width than this optical array limited spacing, at least 88×2 plus a few more like sustain x2.
