Neutrinos are some of the strangest particles we have encountered so far. About 100 billion of them are going through every square centimeter on Earth per second but their interaction rate is so low that they can easily zip through the entire planet. This is how they earned the popular name ‘ghost particle’. Neutrinos are part of many unsolved questions in physics. We still do not know their mass and they might even be there own anti-particles while their siblings could make up the dark matter in our Universe. In addition, they are valuable messengers from the most extreme astrophysical phenomena like supernovae, and supermassive black holes.
The neutrinos on earth have different origins: there are solar neutrinos produced in the fusion processes of our sun, atmospheric neutrinos produced by cosmic rays hitting our atmosphere, manmade reactor neutrinos created in the radioactive decays of nuclear reactors, geoneutrinos which stem from similar processes naturally occurring inside the earth, and astrophysical neutrinos produced outside of our solar system during supernovae and other extreme processes most of which are still unknown.
The Largest Detector Ever Built
Credit: Â –Â IceCube Science Team – Francis Halzen, Department of Physics, University of Wisconsin, CC BY 3.0
Because neutrinos have no charge and are only affected by the weak interaction (and gravity) they are hard to detect. Some experiments use large tanks filled with pure water and equipped with light sensors as detectors. Neutrinos can knock out electrons from the water molecules that will travel faster than the speed of light in that medium and thereby produce Cherenkov light, which is also responsible for the healthy blue glow that emanates from nuclear reactors. The IceCube experiment takes advantage of this detection method on a much larger scale. Instead of building a huge water tank, they buried 86 strings equipped with a total of 5,160 light detectors up to 2,500 m deep in the Antarctic ice. The total volume of the detector is one cubic kilometer which corresponds to a target mass of one gigaton and is thus the largest detector ever built.
Neutrinos from Supermassive Black Holes
Credit: Rothwild, CC BY-SA 3.0
A great success of IceCube was the first detection of high-energy astrophysical neutrinos in 2013. Before that, the only neutrinos from astrophysical sources outside our solar systems were detected during a supernova in 1987. At the time of the IceCube observation, it was not clear where these neutrinos originated but this changed in 2017 when another high-energy neutrino event could be attributed to a known gamma-ray blazar. A blazar is formed by an active galactic nucleus (AGN), the center region of a galaxy that is theorized to house a supermassive black hole. Mass falling into the black hole produces a pair of relativistic jets that can be seen as a bright source throughout the electromagnetic spectrum when they are directed towards the observer. Recently, Russian researchers made another progress in identifying the sources of astrophysical neutrinos. They compared the IceCube events with data from a network of radio telescopes and found them to be associated with several radio-bright AGNs. Multimessenger astronomy like this is a striving field that became even more interesting since we added gravitational waves to the game. To enable the coincidental observation of neutrinos, electromagnetic radiation, cosmic rays, and gravitational waves from astrophysical sources, different telescopes around the world are joined by the Astrophysical Multimessenger Observatory Network (AMON)
Neutrino Detection with Radio Pulses
Credit: The ANITA collaboration
IceCube is not the only neutrino experiment at the south pole. The Antarctic Impulsive Transient Antenna (ANITA) is a balloon-borne experiment designed to detect radio waves created by very high-energy neutrinos smashing into the ice, known as the Askaryan effect. ANITA detects radio pulses that travel upwards in the atmosphere as they are produced by neutrinos traveling through the earth. An upwards going radio pulse can also be produced by cosmic rays coming from above when the signal is reflected off the surface of the ice, however, during reflection it changes polarization. ANITA can therefore distinguish these radio pulses by looking at the phase of the detected signal.
An Unexpected Signal
Credit: Drummermean, CC BY-SA 4.0
The experiment made the headlines when they detected two anomalous events during two separate flights in 2006 and 2014. Both events were consistent with upwards propagating radio pulses produced by neutrinos traveling through the earth. The problem was that the measured arrival angles and energies of the neutrinos were much higher than the expected neutrino flux. The neutrinos must have traveled through more than 5700 km earth and had energies of ~0.5 EeV. Since we know the flux of neutrinos at these energies from other experiments but also from ANITA itself and their interaction rate, there was simply no way that they could have survived traveling through that much rock.
A possible explanation was that the neutrinos came from an intense point source. Some kind of cosmic accelerator, like a supermassive black hole, which shoots out a narrow beam of high energy neutrinos. This explanation was disproven earlier this year by the IceCube collaboration which conducted a search for such point sources in the direction of the ANITA events but found nothing. If the two ANITA events would have originated from a point source, IceCube should have detected many more, which they did not.
The only two remaining explanations for the anomalous events were some systematic error or new physics. In fact, when the ANITA result first came out one collaboration member jumped the gun and tweeted that he thinks they just broke the Standard Model of particle physics. This is typical behavior for scientists who are under the impression that they unexpectedly made a great discovery and you cannot really blame them for getting overexcited. However, in many cases, it leads to embarrassment when the result turns out to be just a fluke. Some recent examples for this include the false detections of superluminal neutrinos and gravitational wave signatures in the cosmic microwave background.
When Tabloids Interpret Physics
In April New Scientist published an article about the ANITA anomaly where they cited an older paper from 2018 by another group of theoretical physicists that interprets the events as evidence for a theory where our universe is the mirrored image of another universe that existed before the big bang. The story was immediately picked up by several tabloids like the UK Daily Star under the headline
“NASA scientists detect parallel universe ‘next to ours’ where time runs backwards”
One can immediately see what is wrong with this headline. Firstly, it connects NASA who is founding ANITA with the theory paper by an entirely different group. Secondly, it pretends as if the theory was a fact instead of being merely one of many interpretations of the data and even not a very likely one. ANITA researchers from the University of Hawaii were evidently annoyed by the false media coverage and issued a press release to clarify that they are in no way affiliated with the theory paper about the parallel universe. One has to point out that the theory paper was written by respectable physicists and should not be regarded as shady.
This is definitely not the first time though that the media has taken scientific speculation at face value. The discovery of dark matter, e.g., was falsely announced several times by major news stories over the past years, whenever an experiment published a result that contained some unexplainable events. Like the ANITA researchers, also in these cases, scientists were very careful not to make any claim of discovery in their publications. Usually, this requires confirmation by another experiment, like the discovery of the Higgs boson had to be seen by both ATLAS and CMS detectors. Journalists are less careful about making such claims as it simply makes for better headlines.
So what is the most likely explanation for the ANITA result? There are numerous papers that try to explain the events with beyond-the-standard-model physics scenarios but some people have also proposed more mundane solutions. One group of researchers has pointed out that radio signals reflected slightly below the ice surface can occur without phase inversion. There is also a possible explanation due to the interaction of cosmic rays with the Earth’s magnetic field. Future experiments like the proposed Payload for Ultrahigh Energy Observations (PUEO), the successor to the ANITA program, may shed some more light on this matter. In addition, the ANITA collaboration is still analyzing the data from their latest flight, and we are eagerly awaiting the results.
Banner image: University of Madison-Wisconsin.
“Neutrinos are some of the strangest particles we have encountered so far. About 100 billion of them are going through every square centimeter on Earth per second but their interaction rate is so low that they can easily zip through the entire planet.”
Be something if that could be harnessed. Unmetered energy everywhere.
All you need is a neutrino shield, and you put it over one half of a wheel filled with buckets of water, simple frictionless bearing in the middle and it will spin like crazy, if you neglect air resistance and assume that the chicken is a sphere.
I thought the horse was a sphere. I guess the chicken is a smaller sphere.
In this instance, we deal with the chicken, not the SI standard horse..
https://video-images.vice.com/_uncategorized/1491344568677-Yang-Maoyuan-image-2.jpeg
Which kind of explains how a draught horse can make about 15HP.
That’s one serious case of bloat!
I advise people to not be in the vicinity when it passes gasses!
That’s what happens when a My Little Ponyâ„¢ is polite about it’s bodily functions. Warning! Do NOT use as a piñata.
100 billion seems like a large number, but is it really? I.E. how much energy is actually in 100 billion neutrinos?
About yay much…
https://upload.wikimedia.org/wikipedia/en/c/c8/Solar_neutrino_flux_spectrum.png
https://journals.le.ac.uk/ojs1/index.php/pst/article/view/859 is a nice paper detailing how to propel spacecraft using neutrino pressure on the sails.
Here’s the money quote: “We find that a thickness of 34000 light years would be necessary if a sheet of osmium were used, whereas neutron star matter could achieve this at 189 km thickness. We conclude that a neutrino sail is not a practical method of propulsion.”
And of course the relevant xkcd: how close would you have to be to a supernova to get a lethal dose of neutrinos. https://what-if.xkcd.com/73/
If they could be produced, modulated and received they would make for a great communications medium, want to call somebody in Australia on your phone, no problem, just call him through the centre of the earth.
Revolutionize the internet. Put every communications monopoly out of business. Upset every totalitarian government. The dark web would thrive with the help of this, an untraceable currency, and magic shipping and delivery.
It has been done already, in a preliminary sort of way. Made in one location and detected in another. So you could modulate the flow and have a communications link carrying a signal. The bit rate may be very low, not suitable for realtime audio.
Key disbursement would be appropriate. Kind of like the whole quantum thing the Chinese are doing with their satellite.
First paragraph, there should be their.
WTF?
Going to retract my WTF.
Between the glue fumes and dyslexia I thought “ANITA” said “ANTIFA”; upon closer inspection, that is not the case.
So, would reversing (or retracting) a WTF, make it a FTW?
B^)
Thanks, that made me laugh !
FYI, Here is a wiki page about a neutrino detector in Northern Minnesota.
https://en.wikipedia.org/wiki/MINOS
The MINOS detector was really something worth seeing, back when it was in operation (and existed).
Last summer when we were vacationing in Ely, I took the “science tour” of the Tower Soudan Underground State Park, hoping to see it again. Unfortunately after the high energy experiments ended, the detectors were dismantled and removed from the mine. So now the science tour is a bit boring, because all you get to see are empty caverns that once housed these really impressive Big Science experiments; chunks of disassembled sensors; and since all the researchers are gone, the tours are now conducted by park interpreters instead of the grad students who used to run them.
The mine tour is separate from the Science Tour, and at least it still shows you the mining equipment and the mines themselves. If you ever head up to Ely, be sure to stop at the park, hop in the elevator car, drop a half mile into a hole in the ground, and take in the Underground Mine tour. See how shaft mining was done in the mid 20th century.
Among the most interesting things I learned is that the iron ore produced by the mine is some of the highest purity iron ore on the planet (hematite with approximately 70% or higher iron content, as opposed to processing lower grade magnetite into taconite pellets.) The Tower Soudan mine did not shut down because it ran out of high quality iron ore. It was shut down only because the old hoist system was too small to raise profitable amounts of ore up to the surface — it became cheaper to open pit mine elsewhere.
That’s all assuming they resume the tours after the pandemic, of course. The hundred year old hoist system is surprisingly expensive to operate (the average cost of a single trip down and back is about $90 worth of electricity, maintenance and labor) so they were considering shutting them down entirely.
Thanks!
I didn’t realize the MINOS+ had shut down until after I posted.
I think it was only a year ago that I first read about it, and whatever I read made me think it was still in operation (sigh!).
Those remote science stations in icy landscapes always look awesome. Can recommend the pictures from the MOSAiC expedition who is currently cruising through the Arctic (or on it’s way home? Not up to date, sorry) to research climate change.
https://www.heise.de/newsticker/meldung/Arbeit-in-der-Dauer-Nacht-Polarstern-Forscher-in-der-Arktis-4656372.html?hg=1&hgi=10&hgf=false
Great wallpaper material, if a bit offtopic :)
The Telescope in the Ice by Mark Bowen is a great book about the history of the hunt for the source of neutrinos and the challenge of building IceCube
Better watch out or you’ll get a surprise.
https://en.wikipedia.org/wiki/The_Neanderthal_Parallax
“this is a striving field”. Thriving? Or striving to find answers? Anyway, curious little critters.
Maybe it is a starving field?
B^)
How does IceCube deal with ice shift? That stuff is moving and can play havoc with construction inside it. Check out the link…
https://en.wikipedia.org/wiki/Project_Iceworm
I tried posting this earlier but apparently the internet ate it.
Nice paper on how thick your sails would have to be to make a neutrino powered spacecraft:
main point:
and xkcd had a great post on how close you would have to be to a supernova to get a lethal dose of neutrinos, in one of his what-if colums called lethal neutrinos. You’d have to be at the edge of the corona of the supernova, at which point you’d get 10E57 neutrinos passing through you.
That reminds me, I was once told;
“If you are close enough to a nuclear blast to worry about the neutrons, that should be the LEAST of your worries!”
B^)
I was working at the Amundsen-Scott South Pole station when the Ice Cube building was being built and I currently do IT for a school district. Whenever I have to clean up any cabling I remind myself that those huge silos on each side of the building….are cable trays.
