Custom Built 12-Port A/V Switch Keeps CRT Well Fed
Classic gaming aficionados who prefer to play on real hardware know the struggle of getting their decades-old consoles connected to a modern TV. Which is why many gamers chose to keep a contemporary CRT TV around for when they want to take a walk down memory lane. Unfortunately those old TVs usually didn’t offer more than a few A/V ports on the back, so you’ll probably need to invest in a A/V switch to keep them all hooked up at once.
That’s the situation [Thomas Sowell] found himself in, except he couldn’t find one with enough ports. Rather than chain switches together, he decided to build his own custom 12-port console selector. With an integrated amplifier to keep everything looking sharp, a handsome walnut and metal enclosure, and a slick graphical interface that shows the logo of the currently selected console on a Vacuum Fluorescent Display (VFD), the final product is a classic gamer’s dream come true.
A peek under the hood.
To switch the audio [Thomas] is using a pair of ADG1606 16-channel analog multiplexers, while video is shuffled around with four MAX4315 8-channel video multiplexer-amplifiers. The math might seem a bit off at first, but he’s using one ADG1606 for each stereo channel and since the switch is for S-Video, each device has a luminance and color signal that needs to be handled separately. The multiplexers are flipped with a ATmega2561 microcontroller, which is also responsible for reading user input from a rotary encoder on the front of the case and displaying the appropriate console logo on the 140×32 Noritake VFD.
You may be surprised to find that [Thomas] considered himself an electronics beginner when he started this project, and that this is only the second PCB he’s ever designed. Was this a bold second project? Sure. But it also speaks to how far DIY electronics has come over the last years. Powerful open source tools, modular components, and of course a community of creative folks willing to share their knowledge and designs, has gone a long way towards redefining whats possible for the individual hacker and maker.
5 thoughts on “Custom Built 12-Port A/V Switch Keeps CRT Well Fed
  1. I’m impressed that analog muxes work this well for this. I had to do something similar a while ago, couldn’t figure out how to avoid crosstalk, and ended up using out a 10-way rotary relay that probably started its life as an aircraft part.
    1. The crosstalk is probably not a significant problem if all consoles are not on at the same time. The flat cables for video signal are a bit questionable also, but I guess it works for a small distance.
      1. I’ve thought about doing a project like this one a few times over the years and every time I end up deciding not to do it because of the possibility of issues like these. I don’t think I could stand it if I put a bunch of time, money, and effort into it and then got worse results than a few $8 a/v switches.
Leave a Reply to jpaCancel reply
