A Tidy Octave Mod For The Casio SK-1
1985 saw the release of the Casio SK-1, a compact sampling keyboard that brought the technology to a lower price point than ever before. However, one drawback of this was that it comes stock with only a 2.5 octave keyboard. [Jonas Karlsson] wanted a little more range out of the instrument, so set about hacking in his own octave mod.
The build consists of fiddling with the SK-1’s microprocessor clock to change the pitch of the notes generated by the instrument. The original clock is generated by a simple LC circuit, which in this mod is fed to an inverter, and then a pair of flip-flops to divide the clock by four. The original clock and the divided version are then both sent to a mux chip. With the flick of the switch, either the original or downshifted clock can be sent to the microprocessor.
With the slower clock feeding the microprocessor, all the notes are downshifted an octave. The resulting sound, which you can listen to on Soundcloud, is similar to what you get when chopping down sample rates. It bears noting, however, that as this mod changes the master clock, other features such as rhythms are also effected.
It’s a great mod which gives the instrument a gloomier, grittier sound on demand. The Casio SK-1 has long been prized for its hackability; we’ve seen them completely worked over in previous mods. If you’ve got your own twisted audio experiments cooking up in the workshop, be sure to drop us a line.
5 thoughts on “A Tidy Octave Mod For The Casio SK-1
  1. As the oscillator is an LC type, I wonder if it would not be easier to change the values of those two components via a multi-pole switch?
    1. That could kind of work, but that would make two separate LC circuits that would need individual tuning. Also I wanted to avoid running the clock frequency to the switch across the whole unit.
  2. Using an LTC1799 clock and a 4 pole rotary switch and a bunch of resistors you can actually do +/- 1 or 2 octave mod. To me this is more useful.
Leave a Reply to JonasCancel reply
