A Nerf Ball Turret Complete With FPV
Sentry turrets have long been a feature of science fiction films and video games. These days, there’s nothing stopping you from building your own. [otjones99] has done just that, with his FPV Nerf Ball launcher.
The system works on the basic principle of launching soft foam balls via a pair of counter-rotating wheels. It’s a remarkably simple way of electrically launching projectiles without a lot of fuss and mucking around, and it works well here. A blower fan is used to gently roll ammunition towards the launcher wheels as required. There’s a hopper-style clip which uses a servo to drop one ball at a time into the launching tube.
An Arduino Uno is responsible for slewing the turret, and handling the firing process. A joystick is fitted with an NRF24L01 radio module to send signals to the Arduino to aim the turret, while an FPV camera mounted on the turret allows the user to remotely see what the turret is aiming at. With a simple pull of the joystick’s trigger, the turret opens fire.
It’s a fun build, and one that shouldn’t do too much damage to anything given the soft pliable nature of the Nerf ammunition. Of course, if you don’t want to aim your turret yourself, you can always go ahead and build yourself an automated sentry gun. Video after the break.
2 thoughts on “A Nerf Ball Turret Complete With FPV
    1. Quite right, thanks for pointing out the video typo, we’ll make sure to change it. (I’m one of the two makers of the original project.)
