Defective 3D Printing For Great Strength
Most of us want our 3D prints to be perfect. But at Cornell University, they’ve been experimenting with deliberately introducing defects into printed titanium. Why? Because using a post-print treatment of heat and pressure they can turn those defects into assets, leading to a stronger and more ductile printed part.
The most common ways to print metal use powders melted together, and these lead to tiny pores in the material that weaken the final product. Using Ti-6Al-4V, the researchers deliberately made a poor print that had more than the usual amount of defects. Then they applied extreme heat and pressure to the resulting piece. The pressure caused the pores to close up, and changed the material’s internal structure to be more like a composite.
Reports are that the pieces treated in this way have superior properties to parts made by casting and forging, much less 3D printed parts. In addition, the printing process usually creates parts that are stronger in some directions than others. The post processing breaks that directionality and the finished parts have equal strength in all directions.
The hot isostatic pressing (HIP) process isn’t new — it is commonly used in metal and ceramic processing — so this method shouldn’t require anything more exotic than that. Granted, even cheap presses from China start around $7,000 and go way up from there, but if you are 3D printing titanium, that might not be such a big expenditure. The only downside seems to be that if the process leaves any defects partially processed, it can lead to fatigue failures later.
We wonder if this development will impact all the car parts being printed in titanium lately. If you need something to print in titanium, consider hacking your rib cage.
6 thoughts on “Defective 3D Printing For Great Strength
  1. Anyone capable of being able to afford applying “extreme heat and pressure” to titanium doesn’t really have to worry about costs. This has “aerospace and military applications” written all over it.
    1. Easier than you’d guess. I used to make tooling to forge titanium, forged around 1800 F, 300 ton presses- but you can totally forge the stuff as a blacksmith like steel, its just springier. Power hammer man. Granted, none of that is as controlled- but a hydraulic press is.
Leave a Reply to Bradley WoodsCancel reply
