Teardown: How Many Teddy Ruxpins Does It Take To Start A Coven?
Well, I did it. I conquered my childhood fear of talking bears and brought a vintage Teddy Ruxpin animatronic stuffed bear into my home. There were and still are plenty of his brethren both young and old to choose from on the auction sites, and when I saw this particularly carefree barefoot Teddy in his Hawaiian shirt and no pants, I was almost totally disarmed. Plus, the description promised a semi-working unit with a distorted voice, and who among us could resist a specimen in such condition? Maybe the tape deck motor is going out, or it just needs a new belt. Maybe the tape itself messed up, and Teddy is fine. I had to find out.
But let me back up a bit. If you don’t know what I’m talking about, Teddy Ruxpin was a revolutionary toy that dropped in 1985. It’s a talking teddy bear that reads stories aloud, all the while moving his eyes and mouth to the sounds. Along with Teddy came special cassette tapes, corresponding story books, and outfits. I wanted one when I was a kid, but was also kind of scared of them. Since they were so expensive — about $250 inflation-adjusted for the bear and a single tape / book / outfit, plus another $15 for four D cells — I never did get one in my youth.
Aloha, Beelzebub
On the day Teddy arrived all the way from Hawaii, I ran out and bought a set of C cells so I could check his condition. To my absolute glee, not only did he work as intended, he looked and sounded downright demonic! I grabbed my phone and started recording.
It’s a barefoot kind of Saturday,
It’s a picnic sort of day
Can we go out and plaaaaaaaaay?
According to the way this song’s supposed to sound, several characters are singing it together. Of course, the phone mic makes it sound worse than it really is, so I made a much longer recording by propping Teddy up in front of my desk mic. If you think you can stand it, there’s another song that starts about two minutes in:
At this point, it was time for experimentation. If you’ll recall, Teddy Ruxpin cassettes are special in that one track contains the audio, and the other holds the encoding for the servo(s) that control his eyes and mouth. I can see through the little viewing window that there is some kind of scwum on the tape itself, which could be the cause of the Satanic sounds. Since I didn’t have any other Teddy Ruxpin tapes lying around, I decided to see how the tape sounded in a regular cassette deck (a Hello Kitty boombox I bought in 1999, lined out to Audacity):
Oh! So that’s another kind of freaky, isn’t it? Those 1960s outer space noises are the sound of whatever encoding was used to drive the eye and mouth servos. But based on the normal-sounding speaking voice when played through a tape deck, it seems that whatever is possessing Teddy is coming from within, and will not be so easily exorcised. That’s cool. All the more reason to perform a vivisection.
But First, A Little Grunge Music
In the meantime, I decided to get another tape to prove that it’s Teddy’s problem, so I got the best possible Teddy Ruxpin tape available: Grunge Music.
Wikipedia will tell you that the term to describe the early 90s Seattle music scene came from a record label executive’s description of one band’s sound, but I honestly believe that it was put into that person’s subconscious by this tape, which makes reference to and samples music made by a class of creatures in the Teddy Ruxpin universe known as Grunges. Somehow, this tape sounds even better than the Summertime one that came with Demonic Teddy.
The astute among you have noticed that the tape is upside down, and I suppose that is in the interest of shorter wires between the playback head and the servos that control Teddy’s eyes and mouth, though it could have been done as an easy way to distinguish Teddy tapes from maxi cassingles. What’s slightly more interesting is that there is a second set of copy protection windows in the top of the tape. I’m thinking that this is what tells Teddy whether the tape is one of his, or just some other ribbon of rust.
Teardown Time
Teddy Tuxpin is a lounge singer by night. He had an act with Mac Tonight back in the 70s before they took separate paths to overnight success.
It really didn’t take long for me to get attached to the Demonic Summertime Teddy, so much so that I bought a second one to do the actual teardown part. I really don’t think there’s much to be afraid of under those screws, but I want the chance to familiarize myself with illiop innards before putting Hula Teddy under the knife.
So anyway, here’s where I screwed up. I wanted to make a recording of Grunge Music through Teddy, but for some reason, I decided to start removing screws, and now the tape doesn’t move anymore.
In the meantime, Teddy Tuxpin showed up, and he works perfectly. So for now, the best I can do is record Grunge Music through Teddy Tuxpin:
And here’s how Grunge Music sounds through Hello Kitty:
And then, I had an idea: buy a total of three more Teddies, hack them all to do my bidding, and make them sing barbershop quartet. I could even sew little matching outfits for them. But I digress.
Since Teddy Tuxpin works well, I am hesitant to open him up, and will probably use one of the others to get all the way inside. I cheated a little bit and found this amazingly Web 1.0 site that presents detailed teardown information in helpful poster board-like format. There are two deep-set Phillips screws at the top of the plastic box, and two tiny, soft-metal screws that are unspeakably easy to strip. I had already tried and failed at one of them before I went looking around to make sure that’s all there was to getting inside.
But Wait, There’s More
In my frenzy to collect Teddies from around the Internet, I also bought one of the newer kinds. Produced by Playskool/Hasbro sometime between 1991 and 1996, these Teddies use cartridge tapes that look a lot like small 8-tracks. This particular bear came with a cartridge dated 1992. Instead of four C cells, these take four AAs, with ‘alkaline strongly recommended’. Everything is smaller, including Teddy himself.
After the 8-track teddies, there was a brief resurgence of regular cassettes in the third generation. Then they moved on to digital cartridges. Teddy sort of ditched the razor-and-blades business model in 2017, and comes with three stories pre-loaded. Other stories are available through an app. Oh, and this time around, Teddy has some seriously creepy LCD eyes. If you really want to get into the Teddy timeline, this trip through the Teddy Ruxpin vault is a good start.
Back to 8-Track Teddy
Against the advice on the inside of the cover, I scrounged up four decidedly non-alkaline batteries to test him out. While 8-track Teddy sounds just fine, neither his eyes nor his mouth are moving. While original Teddy was born with three servos in the head, I’ve heard that newer editions used a single servo, so perhaps it’s just dead or frozen.
Hmm, on second look inside the battery compartment, it says that if Teddy doesn’t animate properly, that you’re supposed to insert fresh batteries, with alkaline strongly recommended. Could it be that easy? The re-chargeables I’m using are only 1.2 Vs. I went out and got some new copper tops, and ’92 Teddy still doesn’t animate. I’m thinking it’s because his snout is askance — maybe he got dropped on his face too many times, or else swung around face-first into something. I’ll have to see if I can fix that.
In the meantime, let’s have a look-see inside, shall we?
Bear In Mind, This Isn’t Over
I don’t have to tell you about the change of feeling that comes with taking something apart. You know, the way that just seeing the inside of something increases your familiarity so much that you never view the outside the same way again.
So what about my childhood fear of talking bears? I must say that Demonic Summertime Teddy caused nothing but delight on my end, and I’m determined to get him chanting again so I can terrorize others. I already bought him a better copy of his Hawaiian shirt, which has a few holes and stains, so this has to happen. But it’ll have to happen in another post, which I’m certain will be a real teddy bear picnic.
I want to thank all the commenters on Elliot’s Not On the Internet post who have pointed me towards various answers to the how-does-Teddy-tick question, such as this GUI authoring tool for producing new Teddy tapes and this old Usenet post about the inner workings. I’m bound to get further than I would have before.
35 thoughts on “Teardown: How Many Teddy Ruxpins Does It Take To Start A Coven?
  1. Why not do a transplant? Take Teddy’s organs and put them in a dragon or whale or whatever. So it works like Teddy, but it’s not a bear.
  2. Now I’m kinda wanting to see demon teddy lead an animatronic death metal band, Crux of Destruxxxion or something.
  3. Kudos, Kristina. The title of this article got me laughing, which was a great introduction to a fun read.
    I remember when those bears came onto the market. I wanted one too, but they were way too expensive for my family to afford. I always wondered what poor Teddy would do if someone put a heavy metal tape in. Anyone still have their cassette copy of Master of Puppets? 😁🤘
    1. “Anyone still have their cassette copy of Master of Puppets? ”
      NO ! because they were all burned at a bonfire we had when those m’fers SUED their own fans for downloading their music – during the Napster days. Not a fan … never more … plenty of other great bands that don’t turn on and sic lawyers on their audience
      1. There’s always Rust in Piece, Persistence of Time, Seasons in the Abyss, or even Practice what you Preach, should your tastes in thrash metal lie elsewhere (as well as many, many other awesome thrash metal albums from that era)
  4. Nice story, brings back old memories. Some years ago (25 ?) I “hacked” a TV Teddy’s transmitter, for my nieces, so they could “speak” thru it. It used some sort of encoding to put voice and servo control on a regular VHS tape. I just probed the transmitter circuit until I found the audio being transmitted and soldered an audio input jack to that point and ground.
    It worked very well. I think the servo control was done directly “on board” in the bear’s circuit, may be just using a preset “amplitude window” to open and close the mouth and eyes simultaneously “in sync” with the audio.
    (Found this online today: https://lostmediawiki.com/TV_Teddy_(partially_found_animatronic_voiceovers_for_VHS_content;_1993) ).
    Best regards,
    A/P Daniel F. Larrosa
    Montevideo – Uruguay
  5. You might find out the servos are appearing to be standard RC stuff, generation id based on the connector which appears to be airtronics style.
    Still available, particularly for you being based in the land of olde tyme collections.
    Tux teddy with a jason goalie mask what can be better?
    1. At first glance, I thought the logo on the PCB in that last photo said “MoM”. I instantly thought of Mom from Futurama, and then suddenly her future evil empire of robots made complete sense. Teddy Ruxpin was just the beginning!
      But no, it says “WoW”. Hopes dashed. ( ._.)
      1. Sorry, Piotrsko. I don’t know why my post is a reply to you, I intended for it to be a new post, far below here. My apologies.
  6. This is the most entertaining and engaging post I’ve seen on Hackaday in ages, not least because it’s the antithesis of the “I ‘hacked’ this together in my half-million state-of-the-art machine shop” model. Also, because you hacked at it and made a few mistakes and just kept rolling like an ordinary person doing ordinary tinkering.
    I’m inspired to step over my chronic imposter syndrome and take my motorcycle apart like I’ve been meaning to do for…well, months.
    Thanks for the inspiration and entertainment. And especially for your straightforward humanity.
    1. Just take lots (and lots) of pictures during the disassembly process so you have a reference to fall back on during reassembly!
      1. Sometimes I feel like having footage for the all important “installation is reverse of removal” is almost compelling enough to film myself as if I had a YouTube channel.
        1. With the cost of movie footage these days (i.e. entirely free) there’s no reason not to. Once it’s all back together, delete those gigabytes and you’re good to go.
          I’ve wanted an overhead camera rig for my bench for a while now. This might be a reasonable excuse.
  7. I am so glad you finally met the teddy of your dreams ;) Now you started a whole family of them!! I can’t wait to see your teddy’s all singing in unison!!! Great write up on this too!!!!
  8. Holes are not for copyright protection. It looks like custom tape type by having center but no extra holes near the write protection tabs (the extra holes of Type 4 but dropping the part shared with Type 2). Cassette_tape article at Wikipedia has a photo that could help you with the holes, or visit page (fill the / as needed) theaudioowl.com cassette-tapes blank-cassette-tape-types. Probably they abused the tooling to get this special ID pattern.
    1. My guess is that it’s to help them distinguish between normal tapes and fancy tapes — you don’t want the left channel of your normal audio driving the servos. (Or whatever.)
    2. The holes are for “write protection.” Many (if not most) cassette players could record as well as playback.
      The little holes in the back edge were to keep you from accidentally recording on a tape that already had something on it.
      Purchased tapes all had both holes.
      Blank tapes had a little breakway tab in the holes. Once you recorded something on one side, you could break out the tab to keep from accidentally recording over it.
      Hold the tape with the recorded side up and the tape towards yourself. Remove the upper left tab to write protect that side.
      If you needed to overwrite a recoding, you could put a piece of tape over the hole. Lacking tape, you could make a little paper wad to fill the hole.
  9. So a completely wild guess, but if I had to encode servo commands onto an audio track for mass production in the late 80s (i.e. analog, robust, and cheap), I would probably look to frequency modulate the analog commands into non overlapping bands / channels, and then mix them out to a low frequency voltage. Not sure if proportional servos from the RC world were cheap enough, so assuming they’d use differential amp to drive the servo.
    OK so curiosity got to me and I looked it up. I guess multi-channel RC controls were already pulse-position in the 80s, so that is what is on the track, but later on they apparently did use FM.
    1. Pwm was started in the ’70s, servos were $20 ea retail so quarter that for WOW, FM wasn’t common until the ’90s because AM was just plain easier with discrete components.
  10. I love this article, but the fact that it’s a “to be continued” is a downer. I guess I’ll just have to grin and bear it.
    And Kristina kudos for doing all the work with your bare hands!
  11. You gotta make a voice-animation version in the shape of Winnie the Pooh, an produce it in China. Flailing arms, rolling eyes, and flapping jaw, while listening to a Xi speech would be hilarious. I could see Putin as He-Man, Eeyore, Joker and Crypt Keeper versions for US leadership too
  12. If you can make four of these sing ‘sit on my face and tell me that you love me’ and put the video on youtube you will get millions of views.
    But they will demonetize you for copyright.
    I’d make one of them a big mouth billy bass.
