The WiFi Pumpkin Is The WiFi Pineapple We Have At Home
While networking was once all about the Cat 5 cables and hubs and routers, now most of us connect regularly in a wireless manner. Just like regular networks, wireless networks need auditing, and [Brains933] decided to whip up a tool for just that, nicknaming it the PumpkinPI_3.
The build is inspired by the WiFi Pineapple, which is a popular commercial pentesting tool. It runs the WiFi Pumpkin framework which allows the user to run a variety of attacks on a given wireless network. Among other features, it can act as a rogue access point, run man-in-the-middle attacks, and even spoof Windows updates if so desired.
In this case, [Brains933] grabbed a Raspberry Pi Zero W to run the framework. It was stuffed in a case with a Alfa Network AWUS036NHA wireless card due to its ability to run in monitoring mode — a capability required by some of the more advanced tools. It runs on a rechargeable LiPo battery for portability, and can be fitted with a small screen for ease of operation.
It should prove to be a useful tool for investigating wireless security on the go. Alternatively, you can go even leaner, running attacks off an ESP32.
5 thoughts on “The WiFi Pumpkin Is The WiFi Pineapple We Have At Home
  1. Can the ESP32 run in monitor mode?
    Can it run firmware that makes it appear as a generic NIC under a larger host, so all those heavyweight tools can run, without having to track down increasingly-scarce Alfa hardware?
Leave a Reply to MyselfCancel reply
