Test Your Capacity For Circuit Sculpture With Flashing Lights
Have you tried your hand at circuit sculpture yet? Well, if you were waiting for the ideal first project with a great build video to go along with it, keep reading. [4dcircuitry]’s 555-based flashing circuit sculpture ticks all the go-for-it boxen for us — the component list is short, the final circuit looks cool, and well, there are blinkenlights.
Of course, it’s not quite a zero-entry project. Although [4dcircuitry] makes it look oh-so easy build it in the video below, they are using 1206 components and an SOIC-packaged 555 timer here. On the other hand, they start by smartly laying everything out on double-stick tape before applying flux and soldering. Then when it’s time to run the wires that no one wants to see, [4dcircuitry] carefully tweezers it from the tape and flips it over, re-using the tape do solder up the back side.
Don’t have the patience to solder 1206? All component sizes are beautiful, as evidenced by this amazing circuit sculpture clock.
15 thoughts on “Test Your Capacity For Circuit Sculpture With Flashing Lights
  1. It doesn’t look like 1206 components, I only see less than 10, but I’ll take your word for it.
    Soldering over 1000 components does sound like a staggering amount of work.
    1. The small black plastic-bodied thing has five hundred fifty five components in it so that’s the bulk of it. It’s just hidden on the back with a bunch of little wires like the article states. That’s what the sticky tape was for.
Leave a Reply to NickCancel reply
