Wii Turned Expansion Card For Broadcast Monitor
For the proper retro gaming aesthetic, plenty of gamers look to old CRT displays. Older games can look better on these displays because the original programmers took their visual characteristics into account. Finding a CRT from the 90s or early 2000s is one option, but an even better option is a broadcast video monitor (BVM) which were extremely high quality CRTs with some other features, like the ability to install a Wii straight to an expansion port on the monitor itself (Nitter).
These monitors were, as their name implies, made for broadcast TV productions. As such, they don’t have the typical video connections that might be found on a consumer unit. Instead, they used modular cards to interface with the monitor. Thanks to an open design for cards made for Sony monitors, [ShankMods] was able to make one for the Wii by “trimming” away the unnecessary parts of the console’s PCB and mapping its video and audio outputs to the slot connector.
While the Wii might not be everyone’s idea of retro, it was still a console that came out when plenty of people still had CRTs as their primary home television. It isn’t as necessary to have a CRT for a Wii as some of the older consoles, but it was very easily adaptable to this single-board design. If you don’t have a CRT and still want the CRT feel, there are ways of retrofitting a more modern display to get this effect, though.
Thanks to [Jonas] for the tip!
9 thoughts on “Wii Turned Expansion Card For Broadcast Monitor
  1. Theres was still one source of a decent monitor at a very reasonable price that has both composite video inputs AND analog tuner capability in addition to its interned use as a cheap digital tuner tv. It’s sold under the Insignia brand at the big yellow BB store and comes in two sizes. The tuner is especially good for devices that had no other video outputs except rf modulated outputs as there are not a lot of good solutions sort of hacking the device itself.
        1. Thanks, I was wondering if it was some European chain.
          If he had just properly called it “Bworst Buy”, it would have been so much easier.
          B^)
        2. Your poor communication skills are not the result of other people being younger. Please learn to express your ideas clearly and concisely. Literacy is important.
Leave a Reply to GarryCancel reply
