Pi Zero Runs DOOM Via Wireless Power
What’s better than a Raspberry Pi Zero running DOOM on a 3.5″ touchscreen? Running it over wireless power, of course!
[atomic14] has been interested in wireless power for a while, and while most of the hardware he’s tested over the years has been less than impressive, he demonstrates one that’s able to reliably deliver 5 V at about 1 A which is more than enough to boot a Raspberry Pi W2 into X and launch DOOM. But while that’s neat, he explains that wireless power isn’t quite yet an effortless solution.
The hardware can deliver 5 V at about 1 A wirelessly, which is plenty, but coil alignment is critical to efficiency.
For one thing, the hardware he’s using — similar to those used for mobile phone charging — need the receiver to be very close to the transmitter. In addition, they need to be aligned well or efficiency drops off sharply. For mobile phones this isn’t much of a problem, but it’s difficult to position a Raspberry Pi and display just so when one can’t see the coils. Misalignment means brownouts and other unreliable operation.
So while the wireless power is capable of running the Pi directly, [atomic14] attempts to put a small battery and charger circuit into the mix in order to make the whole thing both portable and more reliable. But because nothing is easy, he discovers that his charging board — which should be able to output as low as 4.5 V — isn’t able to be adjusted down any lower than 5.66 V. It turns out that a resistor marked 104 (which should be 100 kΩ) is actually measuring 57 kΩ, and the trim pot doesn’t go lower than 10 kΩ. The solution is a bit of component swapping, but we suppose it’s a reminder that sometimes with cheap parts, one pays in other ways.
You can see [atomic14]’s wireless power Raspberry Pi running the classic shooter in the video below. Wireless power may have its issues, but it’s certainly a lot less messy than running DOOM with a gigantic potato battery.
Thanks to [Chris] for the tip!
8 thoughts on “Pi Zero Runs DOOM Via Wireless Power
  1. I bet some supercaps and the required balancing hardware would give you just enough power to re-align the device.
    1. A pair of strategically placed magnets would probably work well to guide the device to its “home” position
  2. A perfect example of one of the problems that make “wirelessly” delivering some of the power from the same cable plugged into a device just centimeters away from the intended recipient of said power pointless…
  3. This really sounds like the UK’s 5G network!
    Wake me up when it can be inducted into the Hall of PoA Frame from about 5 inches from da source and run Quake!
    Can it run Doom? That question needs to be upgraded
  4. Whoa. It is totally revolutionary that a transformer was used to power a single board computer. Whats next. will we have a solar powered calculator?
  5. Everyone’s snarking, but this would have been really cool if it’d been parasitically powered instead of just repurposing an inductive charger.
