Shake, Rattle, Roll, With Your Own Seismograph
We always love to see projects where you can build your own lab equipment so [CompactDIY’s] homemade seismograph caught our eye. The design uses an Arduino with an accelerometer and builds on one of their earlier projects. You can see a video of the device below.
The principle is simple. A hobby servo controls a pen and a stepper motor rolls paper, creating a makeshift strip recorder. Its software uses the Visuino system, which is a flowchart-like system, but it outputs Arduino code. Honestly, we would probably have just plotted the data on a PC, but there’s a certain charm to the strip recorder and the idea would work for other types of data recording projects, too. We thought if you rearranged the stepper motor and cut a paper disk out, you could also have a circular chart recorder easily, which wouldn’t need to friction transport the paper. A clock motor would make it even less dependent on software, too.
If this project interests you, try a Raspberry shake, which isn’t as delicious as it sounds. Or, keep an eye on the entire globe, if you prefer.
5 thoughts on “Shake, Rattle, Roll, With Your Own Seismograph
      1. All these “visual programming languages” fall into the trap of apparent simplicity where even simple programs quickly turn into a mess of a flowchart that is hard to follow and difficult to debug, where a simple declarative program list that loops A, B, C, A… with the complexity tucked away inside functions would be much more readable.
Leave a Reply to Hugo OranCancel reply
