2023 Halloween Hackfest: A Spooky Muscle-Brain Interface
What could be better than a Halloween decoration? Something more perennial, or even something that could also be found in a classroom or lab. Something like [Markus Bindhammer]’s spooky muscle-brain interface. It was inspired by a series called “Tales From the Loop” in which a character’s muscle electrical activity is measured in preparation to adjust his prosthetic hand.
Essentially, it does what you think it does: attach the sensors to your muscles, move them around, and watch the brain light up. [Markus] started with a children’s learning kit that involves molding the brain and discs out of red rubbery goop, the vertebrae out of plaster, and then assembling the whole thing.
Instead, [Markus] molded the brain and vertebrae in two-part silicone for durability, and used two-component colored epoxy for the discs.
As the inspiring series is set in the 80s (we assume the brown, dingy 80s and not the fun, neon 80s), [Markus] gave the enclosure/stand an appropriate color scheme. Inside that box there’s an Arduino Pro Micro, a Grove EMG detector, and a mini step-up converter module. And of course, under the brain, there’s a NeoPixel ring. Don’t miss the build and demo video after the break.
There are a ton of things you can do with blinkenlights for Halloween. How about a light-up candy slide, or a bucket that seems them coming?
4 thoughts on “2023 Halloween Hackfest: A Spooky Muscle-Brain Interface
  1. The show was based on artwork by Simon StÃ¥lenhag, which imagines a world from what appears to be the 1980s, but with impossibly advanced machinery, often depicted as broken down – but not always!
    I definitely recommend taking a look at his original artwork – it’s stunning, and far too easy to find yourself lost in the world he creates.
  2. IT’s weird but they (shops) stubbornly keep trying to make halloween a thing in Europe, and they even sell sacks to collect candy in now, which is hilarious because which European is going to spontaneously join into this UK/US stuff?
Leave a Reply to MikeCancel reply
