Don’t Panic: A Cooperative Bomb Defusing Game
[Heath Paddock] wanted to confound his friends with a game that mimics an escape room in a box. About six months after starting, he had this glorious thing completed. It’s a hardware version of a game called Keep Talking and Nobody Explodes where players have five minutes to defuse a suitcase bomb. This implementation requires at least two players, one with the box-bomb itself, and one who holds all the knowledge but can’t see the box-bomb to defuse it.
The wiring of the Mastermind module.
[Heath]’s version has twice as many modules as the original game, each hand-wired one driven by an Arduino. One of the modules is an LED maze. There are two green anchor LEDs in one of six configurations, and and blue and a red LED.
The object is to move the blue LED next to the red one without touching any walls. Of course, the box-holder can’t see the walls and must describe the configuration of the anchor LEDs to their partner in order to get started.
All of the modules are quite different, which likely makes for an extremely fun and challenging five minutes. [Heath] reports that getting inter-module communication down was a long road. Eventually, [Heath] settled on a mesh network configuration and connected everything in a big loop. Be sure to check out the walk-through video after the break.
This isn’t the first time we’ve seen a hardware implementation of this game. Here’s one that uses a Raspberry Pi.
5 thoughts on “Don’t Panic: A Cooperative Bomb Defusing Game
    1. A couple of the modules could be played with the official manual, but must of the modules were either my own design or they were modified. For example the official maze module is a 6×6 grid and mine is 8×8.
  1. This is great – I’ve contemplated a similar, physical version of “Keep Talking” and I’m delighted that somebody did it! I really like how the modules are hand wired.
    It’d be neat if there was a standard that you could build modules against, and then people could swap modules. It’d also be very cool if modules could talk to each other and reference each other’s state.
    1. The modules do send messages to each other. For the most part they solve independently, but many of the modules change based on the number of strikes.
Leave a Reply to AaronCancel reply
