Orange FM Brings Radio To The GameBoy
An amber on black interface on a green reproduction Game Boy screen. It has the FM station 88.9 in large letters in the middle of the display and "Ice Cream (Pay Phone) by Black Pumas" displayed in a box below. A volume indicator is on the left side of the tuner numbers and various status icons are along the top of the screen. A paper cutout of an orange is next to the Game Boy on a piece of paper with the words "Orange FM Prototype" written underneath.
We’ve all been there. You left your Walkman at home and only have your trusty Game Boy. You want to take a break and just listen to some tunes. What to do? [orangeglo] has the answer now with the Orange FM cartridge.
This prototype cart features an onboard antenna or can also use the 3.5 mm headphone/antenna port on the cartridge to boost reception with either a dedicated antenna or a set of headphones. Frequencies supported are 64 – 108 Mhz, and spacing can be set for 100 or 200 kHz to accomodate most FM broadcasts setups around the world.
Older Game Boys can support audio through the device itself, but Advances will need to use the audio port on the cartridge. The Super Game Boy can pipe audio to your TV though, which seems like a delightfully Rube Goldberg-ian way to listen to the radio. Did we mention it also supports RDS, so you’ll know what that catchy tune is? Try that FM Walkman!
Can’t decide between this and your other carts? Try this revolving multi-cart solution. Have a Game Boy that needs some restoration? If it’s due to electrolyte damage, maybe start here?
12 thoughts on “Orange FM Brings Radio To The GameBoy
  1. Neat! I guess if anyone wanted more than FM, there’s already projects using the si4732 chips to draw from. But FM with RDS is already plenty cool given the gameboy aspect.
    A cassette walkman can be adapted to pipe the audio for a phone call through it, meaning if you were to call WWV, you could have a Rube Goldbergian talking clock. Or you could just make everyone around think you’re nuts for holding a conversation with a tape player, if you rather. (It’s a bit less impressive if you know that those adapters are effectively just a bluetooth headset crammed inside an empty cassette and you need a phone or other device in your pocket to work, but still.)
    1. This cart uses the si4705, which I went for because of the ability to have the internal trace antenna. This lets you use the cart without any external antenna which is a nice fit for the game boy cart! But I may experiment with some of the other si chips in the future.
Leave a Reply to JoshuaCancel reply
