RC Submarine Build Starts With Plenty Of Research
RC submarine surfaced in a pool
[Ben]’s a 15-year-old who loves engineering and loves taking on new challenges. He’s made some cool stuff over the years, but the high water mark (no pun intended) has to be this impressively documented remote controlled submarine.
His new build starts off with more research than the actual building. [Ben] spent a ton of time investigating the design of the submarine from its shape, to the propeller system, to the best way to waterproof everything, keeping his sub in tip-top shape. He decides to go with the Russian-style Akula submarine, which is probably the generic look that most of us would think of when we hear the word submarine. He had some interesting thoughts on the propeller system (like the syringe ballast we’ve seen before), and which type of motor to use. In the end, he decided with four pumps that would act essentially as thrusters. fill a chamber with water, allowing the submarine to submerge, or fill with air, making the submarine buoyant, allowing it to resurface.
However, what we found most interesting about his build is how he explains the rationale for all his design decisions and clearly documents his thought process on his project page. We really can’t do [Ben]’s project justice in a short post, so head over to his project page to see it for yourself.
While you’re at it, check out some of these other cool submarine builds that we’ve featured here on Hackaday
19 thoughts on “RC Submarine Build Starts With Plenty Of Research
    1. Torpedoes actually might have been practical if Estes MicroMax motors, about 1/4″ dia and 1″ long, were still available. They wouldn’t have gone far, since they were intended for backyard launching…but it would have been an impressive touch.
      1. The regular engines worked fine underwater when my “boats” turned into submarines the second they were ignited in the creek next to my house as a kid. Sadly the heavily painted tissue paper balsa frames (scraps from rocket fin cutouts) rarely made it more than 20 feet before collapsing (shredding). Sadly my hydrodynamic engineering was sub-par at age 10. Mounting the engine high in the back to keep them dry until ignition was never compensated by a planing suitable surface on the bottom front.
  1. I am building a Submarine myself, and looked at this project for one specific answer- How does the submarine receive commands. The creator has used a RC receiver, which operates at 2.4Ghz. In water, the range is extremely limited. I was wondering how it all worked.
    1. It would be nice if there were some videos to see it in action.
      For this sub, it is positively buoyant and requires active use of thrusters to force it underwater. If it dives too deep and the signal is lost, the thrusters will turn off and the sub will float back to the surface. Once back at (or close to) the surface it can receive commands again.
      1. That isn’t what the article says-
        “he decided with a pump that would fill a chamber with water, allowing the submarine to submerge, or fill with air, making the submarine buoyant, allowing it to resurface.”
        That’s the kind of definition of a static diving sub. The kind where it’s neutral or maybe a tiny bit positive and requires thrusters or dive planes is called dynamic diving.
          Yes, but, the HaD article appears to be wrong. Reading what the builder wrote, they claim to use 4 small pumps to move the vessel up and down, although they need use the control surfaces to start the dive (i.e. cover the pumps in water).
          Correct. And this is what the builder appears to do. No ballast tanks for achieving neutral buoyancy.
    2. Doesn’t work under water at all but some people will run a buoy and wire to the surface
      Older FM radios still work- 6-8 feet of pool water, a lot more in unchlorinated. And only a few inches in salt water.
      Mostly you only run just under the surface in lakes anyway.
  2. In the end, he decided with a pump that would fill a chamber with water, allowing the submarine to submerge, or fill with air, making the submarine buoyant
    On the contrary, to avoid complexity and dealing with pressurised air, he went with a fixed ballast and four submersible aquarium pumps as vertical thrusters. As noted the downside is that all four must be submerged before its functional, to counteract that he uses control surfaces and forward thrust initially. I like the simplicity and ominous-looking ports.
    Great build!
Leave a Reply to DigitalzombieCancel reply
