Modular Magnetic LED Matrix
[bitluni] seems rather fond of soldering lots of LEDs, and fortunately for us the result is always interesting eye candy. The latest iteration of this venture features 8 mm WS2812D-F8 addressable LEDs, offering a significant simplification in electronics and the potential for much brighter displays.
The previous version used off-the-shelf 8×8 LED panels but had to be multiplexed, limiting brightness, and required a more complex driver circuit. To control the panel, [bitluni] used the ATtiny running the MegaTinyCore Arduino core. Off-the-shelf four-pin magnetic connectors allow the panels to snap together. They work well but are comically difficult to solder since they keep grabbing the soldering iron. [bitluni] also created a simple battery module and 3D printed neat enclosures for everything.
Having faced the arduous task of fixing individual LEDs on massive LED walls in the past, [bitluni] experimented with staggered holes that allow through-hole LEDs to be plugged in without soldering. Unfortunately, with long leads protruding from the back of the PCB, shorting became an immediate issue. While he ultimately resorted to soldering them for reliability, we’re intrigued by the potential of refining this pluggable design.
The final product snapped together satisfyingly, and [bitluni] programmed a simple animation scheme that automatically updates as panels are added or removed. What would you use these for? Let us know in the comments below.
5 thoughts on “Modular Magnetic LED Matrix
  1. Thats pretty darn cool. But trying to work with those LED´s i had one issue. I really wonder how it performs when the screen gets bigger. Datarate is fixed, every LED wants 24databits. FPS rates are probably pretty limited once you cross ~32×32.
    1. you would just need to engineer it to specification :)
      if you need a higher bitrate than the bus can provide, you need to have multiple buses. maybe a faster micro with more GPIO pins or maybe a bunch of small micros on a common bus? i’m a little tickled imagining all of the possibilities for the common bus
  2. “potential for much brighter displays.” ??? what difference makes the use of WS2812 in comparison to let´s say standard HUB75 modules ? they also exist in P8 (pitch 8mm)
    1. If they’re multiplexed then by necessity they’re not on all the time. Although you can mitigate it by driving the LEDs a bit harder because they’re not on all the time .
  3. interesting for game
    many yesars ago firma make colod screen game , next hasbro buy licence and make a black-white version
Leave a Reply to WeaselCancel reply
