RF Detector Chip Helps Find Hidden Cameras And Bugs
It’s a staple of spy thriller movies, that the protagonist has some kind of electronic scanner with which he theatrically searches his hotel room to reveal the bad guys’ attempt to bug him. The bug of course always had a flashing LED to make it really obvious to viewers, and the scanner was made by the props department to look all cool and futuristic.
It’s not so far-fetched though, while bugs and hidden cameras in for example an Airbnb may not have flashing LEDs, they still emit RF and can be detected with a signal strength meter. That’s the premise behind [RamboRogers]’ RF hunter, the spy movie electronic scanner made real.
At the rear of the device is an ESP32, but the front end is an AD8317 RF detector chip. This is an interesting and useful component, in that it contains a logarithmic amplifier such that it produces a voltage proportional to the RF input in decibels. You’ll find it at the heart of an RF power meter, but it’s also perfect for a precision field strength meter like this one. That movie spy would have a much higher chance of finding the bug with one of these.
For the real spies of course, the instruments are much more sophisticated.
6 thoughts on “RF Detector Chip Helps Find Hidden Cameras And Bugs
    1. I had to follow your link to see if the 555 was being used as a calculator, or if it the calculator was used for 555 component values. (The latter)
  1. with this kind of instrument i always think what an advantage an analog output stage would be. use your brain as much as possible for the signal-classification problem, especially when it comes to transients as you move it around
Leave a Reply to Greg ACancel reply
