Retrotechtacular: Quest For The “Big Boy” CRT Finds New Home In Mini Doc
Size comparison of a 27 in CRT TV next to a 43 in CRT TV.
To celebrate the twentieth anniversary of their Trinitron line of televisions, Sony launched the KX-45ED1. At forty three inches the screen on this particular model made it the largest tube television in the world, and it came with the kind of price tag that if you need to ask…you can’t afford it (likely around $100,000 USD today). Three decades later, only two of these mythical displays were thought to exist and [shank] chronicled his quest to acquire one of the last remaining “Big Boys” in the mini documentary below.
As it turns out, one of these gigantic tube televisions was located on the second floor of a restaurant in Japan still sitting in the same place it was installed in 1989. It hadn’t moved in the intervening decades, because the television and its specialized support stand weighed over 500 pounds. Having an object that heavy physically moved down a flight of stairs would seem to be the most formidable challenge for most, but compounding the issue for [shank] was that the building housing this colossal CRT was set to be permanently closed in less than a week.
With next to no time to arrange an international flight, [shank] utilized the power of internet to ask for help from anyone currently living near the “Big Boy” CRT’s soon-to-be final resting place. It just so happened that a fellow retro tech enthusiast based in Japan saw the post, and traveled over an hour by train at a moment’s notice to aid [shank]. The heartwarming story of total strangers united by a common interest of preserving a rare piece of tech history is certainly worth a watch. Let alone the goofy size comparison footage of the smallest CRT display sitting on top of the biggest one.
For more on tube TVs and the like, check out this article by Dave on retro gaming on CRT displays.
36 thoughts on “Retrotechtacular: Quest For The “Big Boy” CRT Finds New Home In Mini Doc
  1. I have a friend in the broadcast business who may have had one of those (deductible, since he was on 24 hour call to deal with transmission issues). I’ll have to ask him. He had it in his living room, I remember it was a Sony Trinitron. When he moved, it went somewhere. He did say it took both him and his grown son to move it.
      1. He landfilled it and replaced it with a flat panel. Not everything is worth saving. He got it at cost from the Sony rep. And yes, both he and his son are big people. Trinitrons are awesome, though…I had a smaller one and it had a noticeably better picture.
    1. That was probably a 37″ CRT. Still a monster but not as heavy and much less expensive. My parents had one, and that was after my dad retired.
    2. …yess about +80lbs 37in…multi band.. multi voltage …moved back usa in 2000 new..sony triniton …..another sony triniton 26in usa model..bought in California SF bay area now ..both working …unused in last 15yrs..so very good condition …come buy / gett …d
    1. Me too. It seems that I’ll have an new job opportunity if HaD hires, or I’m loosing way to much time on the tube.
      1. it’s a youtube staple to copy another video and “minor alteration later” produce their version, it’s a HaD staple to not read the article fully :-P , I come to HaD to get articles not on a code watching my moves but more on interests of the authors here. while keyboards are great I would love to see some more projects covered, i’ve submitted many but not seen one pushed.
      1. Power vs Exponential can be very confusing wording.
        One increases the base of the exponential and the other increases the exponent.
      1. The Trinitrons I’m aware of were flat face. The flat face has to be very thick to hold back the atmosphere; the curved surfaces can be much thinner. Consequently the face is the heavy part of the CRT, holding back about 13,000 pounds of air pressure. The weight of the glass needed to support the CRT pales in comparison. The required thickness of the glass is proportional to the length of the shorter axis of the face, i.e. linear. (A mechanical engineer should check me on that.) The area of the face is approximately diagonal squared divided by 2, i.e. power of 2.
        Mass is proportional to thickness times area, = power of 1 times power of 2 = power of 3. Other features of the tube will grow somewhere in the range of power of 0 to power of 3. Thus the total weight of the tube grows no faster than the cube of the diagonal. It is not exponential.
        1. “The Trinitrons I’m aware of were flat face.”
          I beg to differ, they are flat in the vertical, but cylindrilical on the horizontal portion of the face. The electron guns were positioned horizontally instead of delta like most CRTs, which made the number of adjustments to magnetic steering of the electon beam easier.
          A very wise invention, but $ony still sucks!
          B^)
        2. You’re mixing up some details. All TVs are heavier at the front because the tube is physically larger there (it tapers to the rear). Flat glass CRTs were available from many (all?) manufactures towards the end of their common use and yes this did make them even heavier as it required thicker glass at the front due to not having the advantage of a stronger arched shape. The TV in the video isn’t one of those though. The largest flat glass CRT Sony made came later (2000s) and was a 40″ inch TV, weighing a similar amount as this 43″ behemoth due to the extra front thickness.
  2. This made me realize that I never knew how old big screen TVs worked (the thick bois that were practically their own entertainment unit) All we had were CRTs so I just assumed they were some fancy giant tube.
    Looks like most large TVs back in the day were rear projection TVs. With some having a small CRT in them that is projected to the main screen.
    I had thought those really only existed when DLP took off for awhile as the cheap way to make big TVs.
    It’s interesting how much display technology has changed.
      1. I’m specifically referring to what I had always heard called a Bigscreen TV. Larger than 37″ and practically their own entertainment unit. I think most would have large speakers at the bottom below the screen.
  3. In the early 2000’s I had a monster CRT monitor. Must have weighed about 50lbs. No idea what the brand was, but I wish I still had the thing. Movers ended up breaking it. Sigh
  4. This is great! I recently bought a CRT television for some retro games (still haven’t got the Atari 2600 working and set up yet). The last advertised it as 20 or 21″. It turned out to be I think 32″. We had to get her guy neighbor to help load it into the car. Then when I got home, I had to get my guy neighbor to help me carry it into the house.
    1. Heh. In a similar vein, a couple of years ago I acquired a 32″ Trinitron, which was correctly advertised as such. However, I didn’t realize until I came to pick it up that it was a console unit! I had been expecting to be able to take the TV off of its stand, but when that turned out to not be possible, well… let’s just say that trying to shoehorn a giant piece of electronics furniture into the back of my little Honda CR-V was an interesting challenge. It fit, but only by the slimmest margin. I ended up using an engine hoist to get it out.
  5. I have a friend that got into high def early with a very heavy CRT in wide screen full high def. Not this heavy but but the big store delivered it and some years later as plasma and then LCD got cheaper it was showing linearity bugs and some relatives took it off his hands. I never wanted to even move it yet look into it if it had real problems. I still have the outboard tuner with DVI out (pre-HDMI) the only input for the TV.
    Biggest CRT ever is the one depicted in the film Fahrenheit 451 (1966) both a little wide screen table set which looks real and the wall sized screen are seen. When Montag is busted and has to burn his books instead he blasts that big tube and it implodes in all it’s glory and his boss gets burned.
  6. I think of the 4 megapixel display made by $ony in the early 1990s for the FAA to replace the big green round CRTs for the Air Traffic Controllers. Probably the largest CRT that I have ever seen.
  7. When I was in desktop support in the 90s we got about 40-50 17″ Trinitron monitors for the coders. 75 lbs of fun! I was the only desktop support person who was also tasked to write mission-critical code, so I had one. Did I mention that the ID10ts in the mail room refused to let us have a freight elevator key OR move the computer gear for us, even when sealed in the original packaging? My back remembers very well! I often carried one of those suckers up and down the stairwells. They were the reason you had to be able to pick up 75 lbs to be hired for desktop support. Then the mail room postage machine malfed out and they came to me.” Heh heh sorry pals that machine is leased and Egghead ain’t touching it” Teaching them the truth of the old adage: “Bind not the feet of the kine that tread the grain” One freight elevator key would’ve saved them 2 weeks of downtime, as I had an identical video card in my home supply, as well as the security bits to open it. The “do not tamper” stickers? Hee hee hee borrow a heat gun from the UniSys FE!
    I told the mailroom supervisor that when I left.
  8. Even the 17″ Zenith Trintron flat-screen monitors weighed 72 lbs! My back remembers! We had 50 of those babies. After the first World Trade Center attack – the bomb in the parking garage – some of us had to horse those babies down the stairs as the elevators were suspect. Ah youth and stubbornness!
    1. In 2010s we often used obsolete Trinitron CRTs grabbed from e-waste collection point as reactive tragets on shooting range. Funny thing is they sometimes resisted being shot with .22 LR.
  9. Last year I had a family friend who’s moving into assisted living. He used to be number one at Coast guard intelligence then became VP of SAIC when he got out. I can imagine it paid pretty well because he treated himself to the biggest, baddest TV around at the time. It was this exact TV in this article. Anyway his son ( a Marine Colonel) needed to get rid of it because the house was being sold. We were shocked at how heavy it was. We barely made it down a flight of stairs. Lol. We had another steep / narrow flight of stairs to go which we were not looking forward to. I had a sawzall nearby and decided I’ll just cut it up into pieces to make things easier. Well that was a stupid idea because 99.9% of the week was in the tube. Lol! Now we were stuck with a very unwieldy, extremely heavy glass tube which was difficult to get a hold of with our hands.
    We finally made it without a implosion. The tube even survived a hard landing in the sea container which is used for electronics recycling at the landfill. I had no idea how rare these things were. I would have saved it if I did.
Leave a Reply to AnonymousCancel reply
