Making Sure Your Patch Cables Are Ready For RF Work
How do you know that your patch cables are good? For simple jumper wires, a multimeter is about all you need to know for sure. But things can get weird in the RF world, in which case you might want to keep these coaxial patch cable testing tips in mind.
Of course, no matter how high the frequency, the basics still apply, and [FesZ] points out in the video below that you can still get a lot of mileage out of the Mark 1 eyeball and a simple DMM. Visual inspection of the cable and terminations can reveal a lot, as can continuity measurements on both the inner and outer conductors. Checking for shorts between conductors is important, too. But just because the cable reads good at DC doesn’t mean that problems aren’t still lurking. That’s when [FesZ] recommends breaking out a vector network analyzer like the NanoVNA. This tool will allow you to measure the cable’s attenuation and return loss parameters across the frequency range over which the cable will be used.
For stubborn problems, or just for funsies, there’s also time-domain reflectometry, which can be done with a pulse generator and an oscilloscope to characterize impedance discontinuities in the cable. We’ve covered simple TDR measurement techniques before, but [FesZ] showed a neat trick called time-domain transformation, which uses VNA data to visualize the impedance profile of the whole cable assembly, including its terminations.
3 thoughts on “Making Sure Your Patch Cables Are Ready For RF Work
    1. Yep, says to right on the tin: screenshot at 7:02 has the “Time Domain Reflectometry …” button halfway up on the left side.
      However, it’s a pain in the butt to use: You need to have some kind of divine insight to set the sweep settings right to get a usable range/resolution in the resulting plot. I’m happy to hear of the Copper Mountain solution and looking forward to trying it.
  1. “a lot of mileage out of the Mark 1 eyeball and a simple DMM. Visual inspection of the cable and terminations can reveal a lot,”
    I’d actually point out that a lot of times if you see bits and flecks inside the terminations, it’s not dirt – it’s metal flakes from slightly cross-threading the connector or overtorquing it and damaging the threads. Toss it. Not worth it. Well, or mark it suspect, maybe switch its gender using a cheap female-female, etc. Whatever you do, don’t directly connect them to expensive test equipment like a VNA or something unique/bespoke like an antenna.
Leave a Reply to PaulCancel reply
