Lorem Ipsum 36? Dolor Sit Amet Keyboard!
A 36-key monoblock split keyboard with three thumb keys on each side.
You know, it’s a tale as old as custom mechanical keyboards. [penkia] couldn’t find any PCBs with 36 keys and Gateron low-profile switch footprints, so they made their own and called it the LoremIpsum36. Isn’t it lovely?
Close-up of the RP2040 sitting flush as can be in the PCB.This baby runs on an RP2040, which sits flush as can be in a cutout in the PCB. This maneuver, along with the LP switches in hard-to-find SK-33 sockets results in quite the thin board.
[penkia] says that despite using a 3 mm tray for added rigidity, the entire thing is thinner than the Nuphy Air60 v2, which is just over half an inch (13.9 mm) thick. For keycaps, [penkia] has used both XVX profile and FKcaps’ LPF.
And yeah, that area in the middle is crying out for something; maybe a trackball or something similar. But [penkia] is satisfied with it as-is for the first version, so we are, too.
Do you like 36-key boards, but prefer curves? Check out the Lapa keyboard, which doubles as a mouse.
9 thoughts on “Lorem Ipsum 36? Dolor Sit Amet Keyboard!
  1. I love the cute tiny keyboards but the reality is the combo-keys required to use them are a real pain, which is just my opinion of course – i’m sure if you can put the time in to get used to it then it is good.
    1. yeah i can see the argument for chording if you’re making like a truly portable pocket keyboard (like the twiddler) but for desktop use…i really don’t see the appeal.
      i mean i guess i do see the appeal. if you want to make something “radically different”, then throwing out the practical rules that make every other keyboard look the same is a good first step…just make something impractical :)
      1. biggest reasons are ease of construction and consistency. Fewer keys means fewer parts, lower cost, etc, and having a single layout on all of your keyboards even when you have the desk space is handy. all of my keyboards have and will have a layout based on one that can fit in a trs80 case, because I have one trs80 based computer and don’t want to have to switch between layouts. I put enough effort into learning that layout that I don’t want to put in effort into learning more
Leave a Reply to Greg ACancel reply
