Make A Secret File Stash In The Slack Space
Disk space is allocated in clusters of a certain size. When a file is written to disk and the file size is smaller than the cluster(s) allocated for it, there is an unused portion of varying size between the end of the file’s data and the end of the allocated clusters. This unused space is the slack space, it’s perfectly normal, and [Zachary Parish] had an idea to write a tool to hide data in it.
The demo uses a usb drive, using the slack space from decoy files to read and write data.
[Zachary]’s tool is in Python and can map available slack space and perform read and write operations on it, treating the disparate locations as a single unified whole in which to store arbitrary files. A little tar and gzip even helps makes things more efficient in the process.
There’s a whole demo implemented on Linux using a usb drive with some decoy files to maximize the slack space, and you can watch it in action in the video embedded below. It’s certainly more practical than hiding data in a podcast!
Note that this is just a demo of the concept. The approach does have potential for handling secret data, but [Zachary] points out that there are — from a serious data forensics point of view– a number of shortcomings in its current form. For example, the way the tool currently structures and handles data makes it quite obvious that something is going on in the slack space.
[Zachary] created this a few years ago and has some ideas about how to address those shortcomings and evolve the tool, so if you have ideas of your own or just want to try it out, the slack_hider GitHub repository is where you want to go.
15 thoughts on “Make A Secret File Stash In The Slack Space
    1. Yo, dawg, I heard you like writing useless comments. So I put a useless comment in reply to your useless comment so you can read useless comments while you’re writing useless comments.
  1. Windows-98 era.
    Used to find all sorts of stuff tucked into the slack space. I’d always set any drive cleaners to sweep them. From what I can recall, seemed like a lot of trial-wares used the slack space to hide things.
    Supposedly “un-copyable” streaming audio/video buffers seemed to get put there also.
    If memory serves me correctly, “Cool Edit” (no working “save” function) trial version , did it with your project.
  2. A fundamental part of any forensic drive exam (after imaging) is to look in the slack space. The good (expensive) tools even identify encryption indicators so that you are at least aware someone may be hiding something there.
    Also, IIRC slack space is a good source of pieces of previously deleted files that have not been overwritten.
    Am I missing something here? I’m surprised someone thinks this is new.
Leave a Reply to NikolaiCancel reply
