3D Printed Air Raid Siren Sounds Just Like The Real Thing
Air raid sirens have an important job to do, and have been a critical piece of public safety infrastructure in times of geopolitical turmoil. They sound quite unlike anything else, by virtue of their mechanical method of generating an extremely loud sound output. They’re actually remarkably simple to build yourself, as [MarkMakies] demonstrates.
[Mark’s] build relies almost entirely on 3D printed components and ex-RC gear. The sound itself is generated by a rotor which spins inside a stator. Each is designed with special slots, such that as the rotor turns at speed, it creates spikes of air pressure that generate a loud wail. The rotor and stator are fitted inside a housing with a horn for output, which helps direct and amplify the sound further.
To spin the rotor, [Mark] used a powerful brushless motor controlled by a common hobby speed controller. The actual speed is determined by a potentiometer, which generates pulses to command the speed controller via a simple 555 circuit. By ramping the speed of the motor up and down, it’s possible to vary the pitch of the siren as is often done with real air raid sirens. This action could be entirely automated if so desired.
If you do decide to build such a siren, just be wary about how you use it. There’s no need to go around agitating the townsfolk absent an actual air raid. It’s worth noting that sirens of this type aren’t just used for air raids, either. They’re often used for tornado warnings, too, such as in Dallas, for example. But why not for music?
11 thoughts on “3D Printed Air Raid Siren Sounds Just Like The Real Thing
  1. I’ve always wanted an air raid siren, ideally mounted outside my house and wired to my home security system on a 3 minute delay (so I can still cancel it in case of a false alarm, before the entire neighborhood has to hear it, and I likely end up with a several hundred dollar fine from my HOA).
    It’s just such a classic sound, that drives an instinctive reaction that a bad situation is brewing.
    1. Just keep the siren out of sight, and “play dumb”/act surprised and confused if/when any complaints are made. Providing evidence or proof of a temporary sound’s location is a lot more difficult than say proving an object’s location (simple photograph).
      1. Not just Dallas, pretty standard across Tornado Alley. Tested first Tuesday of every month my entire life at 9am :p
        For Midwesterners, this is the universal sounds of, “come outside and check out those clouds!” XD
  2. I made this back in September 2022. I needed something loud to help move the wildlife on. Where we live, we sometimes get a mob of 50+ kangaroos within metres of the house. When they’re on the move, they can be dangerous so I figured I’d try making some noise.
    Using RC leftovers, my first 3D printer, FreeCAD, and a bit of research into mechanical sound production, I came up with this thing.
    I’d already uploaded a few small designs to Printables, so I added this one too. Then I filmed a short clip through the window, I think my my first YouTube video — and, somehow, it blew up. It’s now sitting at over 770,000 views.
    Later I found Instructables, posted it there, and it ended up being featured. Which probably explains why some of you have seen it before.
    In the end, it didn’t spook the roos or deer at all. But it does work brilliantly for calling my kelpie back when he’s gone bush and out of yelling range. Just as well we don’t have close neighbours.
    We’re lucky that we don’t really have these kinds of sirens here, no air raids or tornadoes here, so I was just guessing air-raid siren when I named it.
Leave a Reply to JustinCancel reply
