3D Print (and Play!) The Super Mario Tune As A Fidget Toy
[kida] has a highly innovative set of 3D-printable, musical fidget toys that play classic video game tunes. Of course there’s the classic Super Mario ditty, but there’s loads more. How they work is pretty nifty, and makes great use of a 3D printer’s strengths.
To play the device one uses a finger to drag a tab (or striker) across the top, and as it does so it twangs vertical tines one-by-one. Each tine emits a particular note — defined by how tall the thicker part is — and plays a short tune as a result. Each one plays a preprogrammed melody, with the tempo and timing up to the user. Listen to them in action in the videos embedded just under the page break!
There are some really clever bits to the design. One is that the gadget is made in two halves, which effectively doubles the notes one can fit into the space. Another is that it’s designed so that holding it against something like a tabletop makes it louder because the surface acts like a sounding board. Finally, the design is easily modified so making new tunes is easy. [kida]’s original design has loads of non-videogame tunes (like the Jeopardy! waiting theme) as well as full instructions on making your very own versions.
Fidget toys are a niche all their own when it comes to 3D printed devices. The fidget knife has a satisfying snap action to it, and this printable linear toggle design is practically a fidget toy all on its own.
34 thoughts on “3D Print (and Play!) The Super Mario Tune As A Fidget Toy
  1. This is really clever.I could see this being used by a fast food franchise as a prize to pair with their hot garbage kids meals. Hopefully Nintendo doesn’t have an issue with the super Mario being used.
    Very fun idea! Thanks for sharing.
      1. Not unless “we” represents something other than normal humans. Most normal people do buy fast food. You need to find people who make concrete judgements, not based on truth, to find radicals who will boycott normal things. That or the easily brainwashed…
  2. This hack really made me smile. Brilliant!
    Now let’s print a cylinder with the tines sticking out radially, in a gentle spiral. The cylinder could be mounted to a horizontal shaft with a crank.
    If a plectrum, adjacent the cylinder, was mounted to a lead-screw, such that it would advance linearly as the cylinder rotated, you might be able to play a whole song… or even one with with a simple bass line or 2-note chords.
    1. I’d say they described something closer to an Edison cylinder player, which had a stylus mechanically synchronised to a helical track – music boxes typically play a bunch of parallel circular tracks (at much lower speed) and repeat each revolution.
    2. Change it up with the tuned comb hanging down, and a drum underneath with nubs sticking up on drum to tick the comb for different notes (or a couple for a cord) as the drum is turned with a crank. Music box…
      Above is nice and simple idea that would be easy to print. Thumbs up from me!
Leave a Reply to NiklasCancel reply
