3D Printing A Useful Fixturing Tool
When you start building lots of something, you’ll know the value of accurate fixturing. [Chris Borge] learned this the hard way on a recent mass-production project, and decided to solve the problem. How? With a custom fixturing tool! A 3D printed one, of course.
Chris’s build is simple enough. He created 3D-printed workplates covered in a grid of specially-shaped apertures, each of which can hold a single bolt. Plastic fixtures can then be slotted into the grid, and fastened in place with nuts that thread onto the bolts inserted in the base. [Chris] can 3D print all kinds of different plastic fixtures to mount on to the grid, so it’s an incredibly flexible system.
3D printing fixtures might not sound the stoutest way to go, but it’s perfectly cromulent for some tasks. Indeed, for [Chris]’s use case of laser cutting, the 3D printed fixtures are more than strong enough, since the forces involved are minimal. Furthermore, [Chris] aided the stability of the 3D-printed workplate by mounting it on a laser-cut wooden frame filled with concrete. How’s that for completeness?
We’ve seen some other great fixturing tools before, too. Video after the break.
14 thoughts on “3D Printing A Useful Fixturing Tool
    1. It’s nice to see a maker with more than one hammer. (Stop 3D printing flat panels, that’s what the laser cutter is for!)
      That said, the dude just re-invented woodworker dog holes and over-engineered them. Mind you woodworkers themselves recently seem to have done the same thing with MFT.
      The simplest system is wedges, as seen here: https://youtu.be/aYh992zQU0A?si=TI_Y3OrmOvIFvFbT&t=313. You usually make them from scrap, with about a 12:1 ratio. You don’t really need those square pieces, the wedges work fine against the dog (the big round pin). Cheap, fast, works – who says you can’t have all three?
      I made some for my laser cutter which amuses me no end.
      1. I did have the same thoughts about the 3D printed panel. That said, if you don’t have a laser cutter and do have a 3D printer, might as well use what you have. I find myself in that situation every other project. Maybe its time to try to find a cheap usable laser cutter…
        I haven’t seen the wedge idea before. Also very clever. I’m not going to die on the hill of bolts being better, in most ways they probably aren’t. I could see both being useful for different reasons.
        Thanks for sharing, I had no idea.
  1. I saw the part about the concrete and thought how my dad taught me the process of “screeding”. There’s a number of ways, but using flat piece of wood or metal, we worked back and forth across the concrete form in a sawing motion, causing the aggregate to sink and a lovely flat surface to result on top. It’s a one man operation on an item this small. Think I’m going to build this since I make a number of fixtures for my cnc.
  2. Hate to be ‘that guy’ but really could have done this with a Lego plate and left the 3D printing to the smaller custom jig pieces. That way there’s a uncountable number of Lego bricks that could be used for stops, and all that’s needed is variable adjustment. Being a fixture table for small wooden boxes and other light assembly, a great deal of force isn’t necessary.
  3. In the CNC machining world its pretty common to machine the negative of a part for workholding purposes. I wonder if it would have been easier in this case to just 3D print the negative of the surface you want to hold. It is not as adjustable but if it is for a large production it would sure be faster.
Leave a Reply to SkalamangaCancel reply
