Learning The Basics Of Astrophotography Editing
Astrophotography isn’t easy. Even with good equipment, simply snapping a picture of the night sky won’t produce anything particularly impressive. You’ll likely just get a black void with a few pinpricks of light for your troubles. It takes some editing magic to create stunning images of the cosmos, and luckily [Karl Perera] has a guide to help get you started.
The guide demonstrates a number of editing techniques specifically geared to bring the extremely dim lights of the stars into view, using Photoshop and additionally a free software tool called Siril specifically designed for astrophotograpy needs. The first step on an image is to “stretch” it, essentially expanding the histogram by increasing the image’s contrast. A second technique called curve adjustment performs a similar procedure for smaller parts of the image. A number of other processes are performed as well, which reduce noise, sharpen details, and make sure the image is polished.
While the guide does show some features of non-free software like Photoshop, it’s not too hard to extrapolate these tasks into free software like Gimp. It’s an excellent primer for bringing out the best of your astrophotography skills once the pictures have been captured, though. And although astrophotography itself might have a reputation as being incredibly expensive just to capture those pictures in the first place, it can be much more accessible by using this Pi-based setup as a starting point.
13 thoughts on “Learning The Basics Of Astrophotography Editing
  1. Despite the obnoxious and contrived “Most don’t know #6” garbage, the author knows what he’s doing.
    But it’s just the adding-lipstick final editing part. He doesn’t cover how to get a good image to begin with. No bias frame, dark frame, flat frame collection and correction. No hotpixel or black pixel correction. He mentions image stacking, but the video doesn’t cover it.
    This video and web page just covers the end of the process, to turn a technically good image into a visually-pleasing (and not technically-correct) one, using the “spaghetti” approach (throw it, see what sticks):
    If you’re interested in the results from this video, you must go through the basics and get good image data first. His website has links and hints to the process, a couple of link levels deep from the linked page.
    1. It is an advertisement for Photoshop, with the site owner getting a cut of the Photoshop sales from Amazon:
      Buy on Amazon
      As an Amazon associate I earn a small commission from your purchase. Thanks for your support!
    2. To those who are interested, but unexperienced, I’d recommend a channel on Youtube called “Nebula Photos” that explains a lot from getting images, to stacking, to final editing, both with free software such as GIMP and proprietary Photoshop, and of course specialized software like Siril/DSS.
      When I was just beginning with astrophotography, everything was clear and understandable until I had stacking result, and his GIMP postprocessing guides helped a lot.
    3. The article does specifically say editing not capturing. They are two quite different skills that make sense to document separately in my mind.
      However I agree, that it’s more of a photoshop ad than anything. There are freeware options that can do everything required.
  2. How interesting, not only are my cell phone and television listening to me, apparently Hackaday has hidden cameras within my home. I got hooked on the Astrophotography bug a couple of months ago and have been gathering imaging data on different targets since then. In the northern hemisphere, at the upper latitudes, it’s not the best time of the year for the most spectacular deep space objects; however, there are a few to snatch now. It’s a somewhat steep learning curve: Gathering the images is one thing but processing them afterwards is a whole other endeavor. There’s tons of YouTube videos to give the beginner a start. My entry level equipment ran about $8500 USD. There are certainly much cheaper routes to go.
    1. This may sound creepy, but we’ve been observing you and we would kindly like to ask you to move the image of grandma 6 inches to the left as it obscures our view. Regarding the listening to your conversation, fear not, we are not actively listening any more since you decided to change your internet radio to another station. Regarding your entry level equipment, we consider to no longer mention the value of it online as this might pose a security risk (although the place you store it now seems like a safe location at this moment).
      PS: we had a poll here and came to the conclusion that 80% of our staff likes your new curtains simply because they now match with the wallpaper as well as improve the overall lighting of the images.
    2. Just for anyone interested but put off by that cost – $8500 may be entry level for a professional setup, but a mobile phone with a manual camera app can get surprisingly impressive results for larger objects like andromeda. You can also make a planetary camera on par with the lower end commercial ones for less than $50 and get an adequate 2nd hand planetary scope for less than $200.
      Obviously, you won’t be capturing saleable quality images at that price, but it’s still immensely satisfying for an amateur. Even for people who can afford to go all in, it’s a great way to learn post processing that will eek out the best possible images from the data you have captured before spending big to capture that extra bit of data.
      1. The new generation of computerised scopes like the S50 will get you great results and are largely automated. You really don’t need to spend 8K on a scope which lets face it you will be lucky to use more than 50 times in a year.
        Also you really don’t need Photoshop. Affinity we do you as well and will cost you a months subscription
Leave a Reply to Big brother 1984Cancel reply
