An RC Car Driven With Old 3D Printer Motors
RC rover/car with red and yellow-sided wheels. Electronics are visible on top of vehicle.
With the newer generation of quick and reliable 3D printers, we find ourselves with the old collecting dust and cobwebs. You might pull it out for an emergency print, that is if it still works… In the scenario of an eternally resting printer (or ones not worth reviving), trying to give new life to the functional parts is a great idea. This is exactly what [MarkMakies] did with a simple RC rover design from an old Makerbot Replicator clone.
Using a stepper motor to directly drive each wheel, this rover proves its ability to handle a variety of terrain types. Stepper motors are far from the most common way to drive an RC vehicle, but they can certainly give enough power. Controlling these motors is done from a custom protoboard, allowing the use of RC control. Securing all these parts together only requires a couple of 3D printed parts and the rods used to print them. Throw in a drill battery for power, and you can take it nearly anywhere!
With the vehicle together [MarkMakies] tested to a rocketing 0.6 m/s fully loaded 4WD. Of course, less weight proves more exciting. While [Mark] recognizes some inherent issues with a stepper-driven all-terrain vehicle, we could see some clever uses for the drive system.
Broken down 3D printers are a dime a dozen, so you should try making something similar by checking out [Mark]’s design files! 3D printers are machines of fine-controlled movement so it’s no surprise to find reuse in these projects is fairly common. Just like this nifty DIY camera slider!
5 thoughts on “An RC Car Driven With Old 3D Printer Motors
  1. This is semi fake. The torque of those steppers without a gearbox makes them not really usable for this purpose. In the video you can observe it rolling downhill..
    1. That’s not accurate. That video does include downhill movement, but Roverling is fully self-propelled using the stepper motors shown — no external push or slope is required. The platform uses high-torque steppers (1.8°/200-step motors) with custom firmware and runs at 20 V with a conservative current limit. While not as efficient as geared motors, they deliver enough torque for slow-speed terrain use.
      Here is additional footage of it operating on level ground if you’re curious: https://youtube.com/shorts/GWybyCDhXEM
      Or if you are still not convinced, build your own and test: https://www.instructables.com/Roverling/
Leave a Reply to Alan WeberCancel reply
