Simulating Empires With Procedurally Generated History
Procedural generation is a big part of game design these days. Usually you generate your map, and [Fractal Philosophy] has decided to go one step further: using a procedurally-generated world from an older video, he is procedurally generating history by simulating the rise and fall of empires on that map in a video embedded below.
Now, lacking a proper theory of Psychohistory, [Fractal Philosophy] has chosen to go with what he admits is the simplest model he could find, one centered on the concept of “solidarity” and based on the work of [Peter Turchin], a Russian-American thinker. “Solidarity” in the population holds the Empire together; external pressures increase it, and internal pressures decrease it. This leads to an obvious cellular automation type system (like Conway’s Game of Life), where cells are evaluated based on their nearest neighbors: the number of nearest neighbors in the empire goes into a function that gives the probability of increasing or decreasing the solidarity score each “turn”. (Probability, in order to preserve some randomness.) The “strength” of the Empire is given by the sum of the solidarity scores in every cell.
Each turn, Empires clash, with the the local solidarity, sum strength, and distance from Imperial center going into determining who gains or loses territory. It is a simple model; you can judge from the video how well it captures the ebb and flow of history, but we think it did surprisingly well all things considered. The extra 40-minute video of the model running is oddly hypnotic, too.
3D model of an Alpaca next to a Llama
In v2 of the model, one of these fluffy creatures will betray you.
After a dive into more academic support for the main idea, and a segue into game theory and economics, a slight complication is introduced later in the video, dividing each cell into two populations: “cooperators” or “selfish” individuals.
This allows for modeling of internal conflicts between the two groups. This hitch gives a very similar looking map at the end of its run, although has an odd quirk that it automatically starts with a space-filling empire across the whole map that quickly disintegrates.
Unfortunately, the model not open-source, but the ideas are discussed in enough detail that one could probably produce a very similar algorithm in an afternoon. For those really interested, [Fractal Philosophy] does offer a one-time purchase through his Patreon. It also includes the map-generating model from his last video.
We’re much more likely to talk about simulating circuits, or feature projects that use fluid simulations here at Hackaday, but this hack of a history model
11 thoughts on “Simulating Empires With Procedurally Generated History
  1. Way way cool! I haven’t watched the full video yet, but I can see the work that went into it.
    As a teenager/child one of my to-do projects was to make a global commodity trading simulator with thousands of different commodities like rice, steel etc etc and let it naturally evolve on its own. This is something very similar, just a lot more complicated and impressive
    1. That game was so fun single player or multiplayer. It really deserves a re release on modern stuff. Is there anything that exists today that uses the same game mechanic?
  2. IMHO, interesting take to use Automata to retrospectively simulate history. I wonder if this approach produces something better than the Tzolkin Calendar’s Long Count doomsday in December 2012 (we all know how that went).
    On a separate note, I notice the “segue into economics”, which is the step in the right direction, adding the infrastructure that powers the empires – which is probably more important than the “solidarity” thingie and I would argue that economics and markets should have been the starting point all along.
Leave a Reply to Sammie GeeCancel reply
