Solar-Powered RC Boat Has Unlimited Range
For RC aircraft there are generally legal restrictions that require the craft to stay within line of sight of the operator, but an RC boat or car can in theory go as far as the signal will allow — provided there is ample telemetry to let the operator navigate. [Thingify] took this idea to the extreme with a remote-controlled boat that connects to a satellite internet service and adds solar panels for theoretically unlimited range, in more ways than one.
The platform for this boat is a small catamaran, originally outfitted with an electric powertrain running on a battery. Using a satellite internet connection not only allows [Thingify] to receive telemetry and pilot the craft with effectively unlimited range, but it’s a good enough signal to receive live video from one of a pair of cameras as well. At that point, the main limiting factor of the boat was the battery, so he added a pair of flexible panels on a custom aluminum frame paired with a maximum power point tracking charge controller to make sure the battery is topped off. He also configured it to use as much power as the panels bring in, keeping the battery fully charged and ready for nightfall where the boat will only maintain its position and wait for the sun to rise the next morning.
With this setup [Thingify] hopes to eventually circumnavigate Lake Alexandrina in Australia. Although he has a few boat design issues to work out first; on its maiden voyage the boat capsized due to its high center of gravity and sail-like solar panels. Still, it’s an improvement from the earlier version of the craft we saw at the beginning of the year, and we look forward to his next iteration and the successful voyage around this lake.
6 thoughts on “Solar-Powered RC Boat Has Unlimited Range
  1. Flexible solar panels covering a sealed body which then doesn’t matter what direction is facing up.
    Electric motor.
    Batteries.
    GPS nav.
    ESP32/RPi/Arduino – to please HaD readership.
    Small enough not to appear on radar.
    So a narc boat then?
    1. I’m not sure whether the economics work out for that.
      Transportation starts at the very cheap end of the product. And the boat has to be built with material brought in from “technologie advanced” areas. So there is a need to scale up the transport capacity of that boat. Then the boat is easily detected by radar. So you need to hide it.
      As far as I know, submarines carry multiple tons of those products.
      1. Don’t do the crime if you can’t do the time. Don’t do it, don’t do it. Don’t go to bed with a price on your head. Don’t do it, don’t do it. Baretta tv show from the 70’s.
  2. Hi everybody,
    in order to exchange experience and to share solution concerning this project, I tried to reach Thingify via the email adress given in the youtube contacts, but unfortunately without succes. So I would appreciate any help to contact him.
    Greetz,
    Olaf Leonhard
Leave a Reply to Olaf LeonhardCancel reply
