Google Japan Turn Out Another Keyboard, And It’s A Dial
There’s a joke that does the rounds, about a teenager being given a dial phone and being unable to make head nor tail of it.  Whether or not it’s true, we’re guessing that the same teen might be just a stumped by this year’s keyboard oddity from Google Japan. It replaces keys with a series of dials that work in the same way as the telephone dial of old. Could you dial your way through typing?
All the files to make the board, as well as a build guide, are in the GitHub repository linked above, but they’ve also released a promotional video that we’ve put below the break. The dials use 3D printed parts, and a rotary encoder to detect the key in question. We remember from back in the day how there were speed dialing techniques with dial phones, something we’ve probably by now lost the muscle memory for.
We like this board for its quirkiness, and while it might become a little tedious to type a Hackaday piece on it, there might be some entertainment for old-timers in watching the youngsters figuring it out. If you’re hungry for more, we’ve covered them before.
Thanks [ikeji] for the tip.
19 thoughts on “Google Japan Turn Out Another Keyboard, And It’s A Dial
    1. I suspect there’s an rf jammer designed to block psychic abilities in the region. alternating current has the tendency to make objects rotate, and brass screws unscrew from fuse boards, but it could also be along the lines of junji ito’s uzumaki, a dark future where we all spiral together into degenerative extinction.
  1. I once showed my typewriter to a friend only 5 years younger than me. It was fun seeing him struggle to get a sheet of paper in. His girlfriend had still used one of those, and she flipped the lever, put the sheet in, aligned the edges to make the paper straight, flipped the lever back and her only problem was finding the carriage unlock lever (which is hard to find on my model). It’s stark to see the difference between a first time-user and a has-not-used-this-technology-often-and-not-at-all-in-30-years-user.
  2. I really like this sense of humor, the return key really got me, I did not see that one coming!
    Regarding the design, I did not expect it to have steppers motors inside, I expected/hoped for a bit more oldskool mechanical clockwork like approach.
Leave a Reply to pelrunCancel reply
