Standalone CNC Tube Cutter/Notcher Does It With Plasma
Tubes! Not only is the internet a series of them, many projects in the physical world are, too. If you’re building anything from a bicycle to a race cart to and aeroplane, you might find yourself notching and welding metal tubes together. That notching part can be a real time-suck. [Jornt] from HOMEMADE MADNESS (it’s so mad you have to shout the channel name, apparently) thought so when he came up with this 3-axis CNC tube notcher.
If you haven’t worked with chrome-molly or other metal tubing, you may be forgiven for wondering what the big deal is, but it’s pretty simple: to get a solid weld, you need the tubes to meet. Round tubes don’t really want to do that, as a general rule. Imagine the simple case of a T-junction: the base of the T will only meet the crosspiece in a couple of discreet points. To get a solid joint, you have to cut the profile of the crosspiece from the end of the base. Easy enough for a single T, but for all the joins in all the angles of a space-frame? Yeah, some technological assistance would not go amiss.
Which is where [Jornt]’s project comes in. A cheap plasma cutter sits on one axis, to cut the tubes as they move under it. The second axis spins the tube, which is firmly gripped by urethane casters with a neat cam arrangement. The third axis slides the tube back and forth, allowing arbitarily long frame members to be cut, despite the very compact build of the actual machine. It also allows multiple frame members to be cut from a single long length of tubing, reducing setup time and speeding up the overall workflow.
The project is unfortunately not open source– instead [Jornt] is selling plans, which is something we’re seeing more and more of these days. (Some might say that open source hardware is dead, but that’s overstating things.) It sucks, but we understand that hackers do need money to eat, and the warm fuzzy feeling you get with a GPL license doesn’t contain many calories. Luckily [Jornt] has put plenty of info into his build video; if you watch the whole thing, you’ll have a good idea of the whole design. You will quite possibly walk away with enough of an idea to re-engineer the device for yourself, but [Jornt] is probably assuming you value your time enough that if you want the machine, you’ll still pay for the plans.
This isn’t the first tubing cutter we’ve featured, though the last build was built into a C (It wasn’t open-source either; maybe it’s a metalworking thing.)NC table, rather than being stand-alone on the bench like this one.
Thanks to [Shotgun Moose] for the tip! Unlike tubing, you can just toss your projects into the line, no complex notching needed.
5 thoughts on “Standalone CNC Tube Cutter/Notcher Does It With Plasma
  1. I found a YT video that was pretty similar a couple of months ago and sent it to a friend, because he has a fiber laser. The issue with plasma torches is they leave a not great surface finish and you sometimes have to do a fair bit of cleanup, but a fiber laser has a lot of advantages as regards both finish and not overheating the adjacent tubing and possibly cooking your tubing rollers.
    However, as my friend pointed out, this project is mostly about the pretty amazing software this guy has created for this, and replicating that in a reasonable timeframe is much more challenging than the hardware.
  2. I will refrain on commenting on the mechanical and control aspects here (I am handicapped by experience in the field and not wanting to pay the vig for missing details) and say that I kind of like it.
    Optimal? no.
    Reasonable? maybe.
    A negative for me is the fixed radial orientation for the torch. It is desirable to be able to fit the joint with controlled contact and bevel for the weld.
    1. An extra axis to tilt the cutter would be great! OTH, the alternatives available to hobbyists– a hole saw in a jig or an angle grinder and a vise– don’t give the perfect bevel, either. I imagine for a homebuilt airplane you’d go the extra to get a perfect fit with hand files, but I think most bubbas with dune buggies just weld a thicker bead to make up for it.
Leave a Reply to m1keCancel reply
