The ZX Spectrum Finally Got An FPS
The ZX Spectrum is known for a lot of things, but it’s not really known for a rich and deep library of FPS titles. However, there is finally such a game for the platform, thanks to [Jakub Trznadel]—and it’s called World of Spells.
Like so many other games of this type, it was inspired by the 3D raycasting techniques made so popular by Wolfenstein 3D back in the day. For that reason, it has a very similar look in some regards, but a very different look in others—the latter mostly due to the characteristic palette available on the ZX Spectrum. A playable FPS is quite a feat to achieve on such limited hardware, but [Jakub] pulled it off well, with the engine able to reach up to 80 frames per second.
The game is available for download, and you can even order it on tape if you so desire. You might also like to check out the walkthrough on YouTube, where the game is played on an emulator. Don’t worry, though—the game works on real ZX Spectrum 48k hardware just fine.
The Speccy retains a diehard fanbase to this day. You can even build a brand new one thanks to a buoyant supply of aftermarket parts.
[thanks to losr for the tip!]
16 thoughts on “The ZX Spectrum Finally Got An FPS
    1. Cassette release by bitmapsoft will have it slightly corrected, but not eliminated fully.
      Not everything is a platform constraint, but a lot of artifacts is due to design decisions avoiding colour clash while maintaining high speed of renderer.
      Thanks for feedback :)
    1. There are games called: “wolfenstein 3d”, “doom” and “quake” on zx spectrum. Unsure if they share anything with original source codes, besides trying to fit the same stylistic and atmosphere. There is also The Dark, and I am certainly missing some others as well.
      But -> World of Spells is the only one that is running fast on original hardware.
    1. Agree that generation above 50FPS does not make much sense as PAL limits it. FPS in this case is just a measure of renderer efficiency, not noticeable by user – and engine gets there only in very simple scenes . Most of the scenes are filled with items, ghosts, fireballs etc. where it gets lower – environment simulation takes a lot of CPU cycles as well.
  1. @jakub will you do. Full indepth write-up? The initial one you’ve done wa great opener. I’d buy a ded tree version if you sat and wrote out a small book going into extreme detail of the whole process with code examples etc! I have many projects in mind for old systems and it was an eye opener
      1. My plan is to write one write-up on itch.io per week, roughly. Trying to balance in-depth details with some poetic descriptions there.
        I am not excluding writing a in-depth book on algorithms inside, there are certain details that I find interesting myself there. Just that I think audience is very small.
        And I actually put raycaster code in https://github.com/trznadelj/zx_raycaster ; it is an older version, around 50FPS rather than 80FPS in benchmark place – but simpler to follow.
Leave a Reply to poglad2011Cancel reply
