Wavebird Controller Soars Once More With Open Source Adapter
Computer rendering of a DIY, purple Nintendo Wavebird controller adapter
After scouring the second-hand shops and the endless pages of eBay for original video game hardware, a pattern emerges. The size of the accessory matters. If a relatively big controller originally came with a tiny wireless dongle, after twenty years, only the controller will survive. It’s almost as if these game controllers used to be owned by a bunch of irresponsible children who lose things (wink). Such is the case today when searching for a Nintendo Wavebird controller, and [James] published a wireless receiver design to make sure that the original hardware can be resurrected.
The project bears the name Wave Phoenix. The goal was to bring new life to a legendary controller by utilizing inexpensive, readily available parts. Central to the design is the RF-BM-BG22C3 Bluetooth module. Its low power draw and diminutive footprint made it a great fit for the limited controller port space of a Nintendo GameCube. The module itself is smaller than the GameCube’s proprietary controller connector.  Luckily for projects like this, there are plenty of third-party connector options available.
When it comes to assembly, [James] insists it is possible to wire everything up by hand. He included an optional custom PCB design for those of us who aren’t point-to-point soldering masters. The PCB nestles cleanly into the 3D-printed outer casing seen in the image above in the iconic GameCube purple. Once the custom firmware for the Bluetooth module is flashed, pairing is as simple as pressing the Wave Phoenix adapter pairing button, followed by pressing X and Y simultaneously on the Wavebird controller. The two devices should stay paired as long as the controller’s wireless channel dial remains on the same channel. Better yet, any future firmware updates can be transferred wirelessly over Bluetooth.
Those who have chosen to build their own Wave Phoenix adapter have been pleased with the performance. The video below from Retrostalgia on YouTube shows that input responsiveness seems to be on par with the original Nintendo adapter. Mix in a variety of 3D printed shell color options, and this project goes a long way to upcycle Wavebird controllers that may have been doomed to end up in a dumpster. So it might be time to fire up a round of Kirby Air Ride and mash the A button unencumbered by a ten-foot cord.
There are even more open source video game controller designs out there like this previous post about the Alpakka controller by Dave.
8 thoughts on “Wavebird Controller Soars Once More With Open Source Adapter
  1. Why put the button offset from the center line of the connector. Would cause less problems long term on the socket if you did that. Right now it puts stress on the socket any time you press the button.
    1. probably less stress on the socket pressing the button than plugging and unplugging a wired controller, i wouldnt worry too much about it
    1. It seems that the module uses Bluetooth to communicate with a PC for firmware updates, but it uses a custom protocol for Wavebird emulation.
      1. I imagine the controller uses the 2.4GHz band, and if a Bluetooth chip gives you low level enough access it can become a generic 2.4GHz comms chip – it handles the radio part, you handle the logic.
Leave a Reply to briantwCancel reply
