Keebin’ With Kristina: The One With The Curious Keyboards
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
I love first builds! They say so much about a person, because you see what’s paramount to them in a keyboard. You can almost feel their frustration at other keyboards come through their design choices. And the Lobo by [no-restarts] is no exception to any of this.
There’s just something about this Corne-like object with its custom case and highly-tappable and variously tilted keycaps. The list of reasons for being begins innocently enough with [no-restarts] wanting a picture of their dog on the case.
A nicely-tented split keyboard with really interesting, 3D-printed keycap profiles.
Image by [no-restarts] via reddit
From there, things get really personal. You may notice the thumb cluster is slightly different — [no-restarts] doesn’t like the thumb tuck required by the Corne to reach the innermost keys. I really dig the homing bumps on the middle thumb keys. Another difference is the splayed layout, as [no-restarts] is especially prone to pinky splay. Finally, there are a pair of OLEDs hiding on the inner sides of the case, which are designed to be visible when tented.
Overall, [no-restarts] is happy with it, but has some ideas for revision. Yep, that sounds about right. The Lobo is all hand-wired, and there’s a PCB with hot swap sockets in its future. If you’re interested in the case files, GitHub is your friend.
Getting a Handle on Grabshell
[kurisutofujp] recently saw a GrabShell in the flesh, and why haven’t I heard of this keyboard before? The next best time is now, so here we go with the explanation, both for myself and the other 9,999.
The dotBravo Grabshell keyboard, which folds and has straps.
Image by [kurisutofujp] via reddit
Essentially, this thing is made for using while you wander around the office (or the Metaverse). You can hold it in mid-air, secured in your Gargoyle-ness with a pair of straps, your fingers wrapped around to hit the alphas.
But you don’t have to use it that way, see. You can stand it up on the desk if you don’t want to type in mid-air. It can also be opened sort of halfway and used like a SafeType vertical keyboard.
If none of this excites you, GrabShell can also be laid flat on the desk. The distance between the two halves in this configuration is quite generous, and frankly, I’m a bit jealous.
So let’s talk about the generous thumbing-around area. As you’ll see in the video below, the left has a joystick and a toggle switch that flips it from arrow keys to mouse cursor. There’s a serious-looking scroll wheel beneath that. All three of these can be pushed in for additional inputs.
The right side of the thumb panel has a sweet-looking trackball that’s housed in a really cool-looking way. Another cool thing: there’s a frigging I2C port on the top, just exposed and hanging out because reasons.
Switch-wise, the board is a mix of hot-swappable Gateron G Pro browns and low-profile Gaterons under double-shot ABS keycaps. I think it sounds nice in the video below; others say it sounds cheap and hollow. To each their own.
The Centerfold: ZMK Dongle Repackaged As Vintage Computer
A three-panel shot of a Apple ][-inspired ZMK dongle.
Image by me using images by [mharzhyall] via reddit
It’s just so cute, that’s why it’s here. The buttons, they do nothing, but that’s okay — they might could do something in the future.
This is a ZMK dongle, like I said in the subheading, and [mharzhyall] put a new case around it. Basically it lets you connect keyboards wirelessly.
Do you rock a sweet set of peripherals on a screamin’ desk pad? Send me a picture along with your handle and all the gory details, and you could be featured here!
Historical Clackers: the Edland Typewriter Was a Total Flop
The Antikey Chop reports that this curious little rook-looking index typewriter was such as flop as to be nearly lost to history entirely.
The Edland typewriter, a spectacular failure.
Image via The Antikey Chop
Produced between 1891 and 1893 by the Liberty Mfg. Company, the machine was conceived by Joseph Laurentius Edland of Brooklyn, NY. All seemed lost until 1964, when a handful of Edlands were found languishing in a warehouse in Galway, NY.
Although only made for two years, there were three different versions developed. The one pictured here is the second, with a metal base and embossed index, whereas the first had a wood base and flat index.
The third version, the Typewheel Edland, had a typewheel for a print element à la the Blick. Edlands cost a semi-reasonable $5 at the outset, but eventually doubled in price.
So, why the absolute failure? It was no better or worse a machine than its contemporaries, but perhaps just wasn’t well-marketed. Another theory is that the Edland failed because they were made of pot metal. Seems reasonable. Want to know how to use one? RTFM (PDF).
Finally, a Keyboard with a Mechanical Watch Movement
Wait, what? Why though? Well, it ticks along as you type, is that cool? It might be fun to see if you can keep up a certain number of keystrokes per second. Okay, I’m warming up to this idea pretty quickly, can you tell?
The Nama keyboard, dubbed after the scientific term for the mammoth, is appropriately named. It can weigh up to an astonishing 19.4 lbs (8.8 kg) depending on the case material. (Consider that a Model M, a proper bludgeoning device in its own right, weighs just 5 lbs (2.2 kg).)
The upper right corner of a mechanical keyboard with a tourbillion watch movement that ticks along as you type and is fun to, um, watch.
This Nama has a tourbillion movement, the granddaddy of them all. Image by Wuque Studio via Notebook Check
Nama comes from Wuque Studio, and was built as an ode to their manufacturing capabilities. Now this is starting to make more sense. They are the Banana Republic to vendor Chilkey’s Old Navy, who are the brand behind the ND75, if that rings any bells.
Now the Nama looks like your basic mechanical keyboard on the surface, but five years of design decisions went into this line. You can get it with an aluminium case (14.5 lbs / 6.6 kg) or a brass CNC’d case (18.95 lbs / 8.6 kg), which of course is what makes it so heavy.
But yeah, the defining feature is definitely the watch movement. You bet your Backspace it’s fully functional except as a watch, and it doubles as a volume control knob, so you don’t have to settle for touching it with just your eyeballs.
Yeah, so the astute among you will have noticed that there are no numbers or hands on the watch movement, which would be, what, tacky? I don’t know anymore. At any rate, it’s protected by a piece of sapphire glass, which should keep Cheetos dust and such out of there.
Oh, you want to know the cost? $749 for the bare-bones with no movement, and $1299 for the brass-bottomed boy with the tourbillion. That’s… actually not that bad for a tourbillion movement.
Got a hot tip that has like, anything to do with keyboards? Help me out by sending in a link or two. Don’t want all the Hackaday scribes to see it? Feel free to email me directly.
6 thoughts on “Keebin’ With Kristina: The One With The Curious Keyboards
  1. That watch movement thingy would be a lot more interesting if you could somehow replace your computer’s RTC with it. Seems like one of those crazy wild west ideas they would have cooked up in the apple ii days before computers had RTCs.
  2. I like how you primed us with that 1890’s piece of kit before showing us a bit of kit still sporting that 1870’s design. They can throw a fancy knob on a fancy encoder, but youve clearly shown that it’s just the same old tired piece of kit cleaned up with a fresh coat of paint.
  3. That Grabshell seems like a pretty well executed product that I might just have to see if I can get hold of affordably. It is very similar to a sketch of an idea I had – but in my case it was more complete cyberdeck putting a similar concept keyboard on the back of a Toughbook CF-H1 – so the front face would be a nice daylight readable touch screen with pen input. Actually started designing that concept more completely before realising I’d never it get it done while the anaemic atom processor still had enough life left in it even when running Linux to be worth the effort for me.
  4. I saw a review of a compact keyboard, available in a number of varieties, and they said it was pretty good.
    What I noticed though is that it did not have Home and End keys.
    It made me wonder for whom all those expensive mechanical keyboards are made. Collectors? Because they are so often not made for people that actually use keyboards, lacking key functionality (pardon the pun) or having annoying layouts that make them useless for people that use keyboards in a professional way I would think.
    But the tech, I mean HAL sensor switches and whatnot, for something that is not suited to be used IMHO.
    I did hear on a podcast that the guy talking had an addiction to buying keyboards and he had quite a few, so it seems a thing that some people buy them to have not to use.
Leave a Reply to lambert4congressCancel reply
