As locked-down as the Amazon Echo Show line of devices are, they’re still just ARM-based Android devices, which makes repurposing it somewhat straightforward as long as what you want is another Android device.
In this case, we’re talking about the first-generation Amazon Echo Show 8, which is a 2019-era device that got jailbroken back in November by [Rortiz2]. The process was then demonstrated in a video by [Dammit Jeff].
Currently only two devices are supported by this jailbreak, with the Echo Show 5 being the other one. If there’s enough interest, there doesn’t appear to be any technical reason at least for why this support couldn’t be extended to other devices. One major reason for jailbreaking is to put LineageOS on your Echo device courtesy of these Echo Show devices recently beginning to show advertisements, with no way to disable this.
The process of jailbreaking and installing the LineageOS ROM is somewhat long as usual, with plenty of points where you can make a tragic mistake. Fortunately it’s pretty simple as long as you follow the steps and afterwards you can even install the Google apps package if that’s your thing. Just mind the 1 GB RAM and 8 GB of storage on the Echo Show 8. In the case of [Jeff] he mostly replicated the home automation and entertainment features of Amazon’s FireOS with far less locked-down alternatives like Home Assistant.
If thereās enough interest, there doesnāt appear to be any technical reason at least for why this support couldnāt be extended to other devices.
Iirc they used an exploit on the specific MTK chip the echo show 5 gen 1&2, and echo show 8 gen 1 used, inorder to put TWRP on it. The other echos have different chips which doesnt support the exploit
Ah, tablets have come far.
The Echo Show 18 and 21 would be pretty sweet deals of a device if we can put LineageOS on them.
+1
Hi, Iām the developer of the exploit, and Iād appreciate it if you could link the XDA threads directly, since theyāre the proper and actively maintained source of information.
Iād also kindly ask that you credit bengris32 from XDA, as heās the one building LineageOS for these devices and is therefore directly involved in all of this.
Also, FWIW, the Echo Show 5 2nd Generation (2021) is now unlockable as well.
These are the relevant XDA threads:
Amazon Echo Show 5 1st Generation (2019) ā checkers:
https://xdaforums.com/t/unlock-root-twrp-unbrick-amazon-echo-show-5-1st-gen-2019-checkers.4762900/
Amazon Echo Show 8 1st Generation (2019) ā crown:
https://xdaforums.com/t/unlock-root-twrp-unbrick-amazon-echo-show-8-1st-gen-2019-crown.4766687/
Amazon Echo Show 5 2nd Generation (2021) ā cronos:
https://xdaforums.com/t/unlock-root-twrp-unbrick-amazon-echo-show-5-2nd-gen-2021-cronos.4772596/
Also, for anyone wondering: the Echo Show 8 2nd Generation is not supported, as it uses a different SoC that is not vulnerable to this exploit.
Thank you for posting all the links
Yeah! Thanks for that.
No need to ask us to include the links — you just did. :)
How about the first generation Echo Show? Thanks to the über-onoxious ads, I have four (yeah, I knowāI’m a sucker) of those that are destined to soon be e-waste if I can’t find a better use for them.
These devices seem like the perfect candidate to run a home assistant dashboard to me
Or fill your trashcan.
When I get an ad, I touch the icon in the lower right screen.
Then a select “Something else” to give feedback.
They I type “**** your ads.” and send.
I get a lot fewer now!
“I get a lot fewer now!” With Amazon running this thing? That seems unlikely. It’s kinda like what happens when you’re reading Google News, see something dumb, click on the three dots, and select “Fewer stories like this”. You’re on your way to being flooded with twice as much of the junk! These days annoying your customers is how you keep them engaged, and Amazon devices have taken this to the extreme.
Alguien me puede ayudar con un Echo Show 15? Tiene cuenta vinculada y no conozco al dueƱo
