Jailbreaking The Amazon Echo Show
As locked-down as the Amazon Echo Show line of devices are, they’re still just ARM-based Android devices, which makes repurposing it somewhat straightforward as long as what you want is another Android device.
Running Home Assistant on an Echo Show 8 with LineageOS. (Credit: Dammit Jeff, YouTube)
In this case, we’re talking about the first-generation Amazon Echo Show 8, which is a 2019-era device that got jailbroken back in November by [Rortiz2]. The process was then demonstrated in a video by [Dammit Jeff].
Currently only two devices are supported by this jailbreak, with the Echo Show 5 being the other one. If there’s enough interest, there doesn’t appear to be any technical reason at least for why this support couldn’t be extended to other devices. One major reason for jailbreaking is to put LineageOS on your Echo device courtesy of these Echo Show devices recently beginning to show advertisements, with no way to disable this.
The process of jailbreaking and installing the LineageOS ROM is somewhat long as usual, with plenty of points where you can make a tragic mistake. Fortunately it’s pretty simple as long as you follow the steps and afterwards you can even install the Google apps package if that’s your thing. Just mind the 1 GB RAM and 8 GB of storage on the Echo Show 8. In the case of [Jeff] he mostly replicated the home automation and entertainment features of Amazon’s FireOS with far less locked-down alternatives like Home Assistant.
13 thoughts on “Jailbreaking The Amazon Echo Show
  1. If there’s enough interest, there doesn’t appear to be any technical reason at least for why this support couldn’t be extended to other devices.
    Iirc they used an exploit on the specific MTK chip the echo show 5 gen 1&2, and echo show 8 gen 1 used, inorder to put TWRP on it. The other echos have different chips which doesnt support the exploit
  2. Hi, I’m the developer of the exploit, and I’d appreciate it if you could link the XDA threads directly, since they’re the proper and actively maintained source of information.
    I’d also kindly ask that you credit bengris32 from XDA, as he’s the one building LineageOS for these devices and is therefore directly involved in all of this.
    Also, FWIW, the Echo Show 5 2nd Generation (2021) is now unlockable as well.
    These are the relevant XDA threads:
    Amazon Echo Show 5 1st Generation (2019) – checkers:
    https://xdaforums.com/t/unlock-root-twrp-unbrick-amazon-echo-show-5-1st-gen-2019-checkers.4762900/
    Amazon Echo Show 8 1st Generation (2019) – crown:
    https://xdaforums.com/t/unlock-root-twrp-unbrick-amazon-echo-show-8-1st-gen-2019-crown.4766687/
    Amazon Echo Show 5 2nd Generation (2021) – cronos:
    https://xdaforums.com/t/unlock-root-twrp-unbrick-amazon-echo-show-5-2nd-gen-2021-cronos.4772596/
    Also, for anyone wondering: the Echo Show 8 2nd Generation is not supported, as it uses a different SoC that is not vulnerable to this exploit.
  3. How about the first generation Echo Show? Thanks to the über-onoxious ads, I have four (yeah, I know—I’m a sucker) of those that are destined to soon be e-waste if I can’t find a better use for them.
  4. When I get an ad, I touch the icon in the lower right screen.
    Then a select “Something else” to give feedback.
    They I type “**** your ads.” and send.
    I get a lot fewer now!
    1. “I get a lot fewer now!” With Amazon running this thing? That seems unlikely. It’s kinda like what happens when you’re reading Google News, see something dumb, click on the three dots, and select “Fewer stories like this”. You’re on your way to being flooded with twice as much of the junk! These days annoying your customers is how you keep them engaged, and Amazon devices have taken this to the extreme.
Leave a Reply to Joe FreemanCancel reply
