Carbon fiber (CF) has attained somewhat of a near-mystical appeal in consumer marketing, with it being praised for being stronger than steel while simultaneously being extremely lightweight. This mostly refers to weaved fibers combined with resin into a composite material that is used for everything from car bodies to bike frames. This CF look is so sexy that the typical carbon-fiber composite weave pattern and coloring have been added to products as a purely cosmetic accent.
More recently, chopped carbon fiber (CCF) has been added to the thermoplastics we extrude from our 3D printers. Despite lacking clear evidence of this providing material improvements, the same kind of mysticism persists here as well. Even as evidence emerges of poor integration of these chopped fibers into the thermoplastic matrix, the marketing claims continue unabated.
As with most things, there’s a right way and a wrong way to do it. A recent paper by Sameh Dabees et al. in Composites for example covered the CF surface modifications required for thermoplastic integration with CF.
Carbon Fibers
There are a number of ways to produce CF, often using polyacrylonitrile, rayon, or pitch as the feedstock. After spinning this precursor into a suitable filament, heating induces carbonization and produces the carbon fiber.
Following this process, the CF is typically in the form of a few micrometer-thick fiber that is essentially pure carbon. To create a structural interface between the CF and the polymer of a composite material, some kind of process has to take place that creates this interface.
The fundamental difference between thermoset and thermoplastic polymers is that thermoset polymers are reacting in the mold as it sets, providing an environment in which the epoxy precursor and hardener can interact with the normally not chemically very reactive CF to form covalent bonds.
In comparison, thermoplastic polymers are already finalized, with covalent bonds between thermoplastics and CF unlikely. This means that the focus with CF-reinforced thermoplastics is mostly on weaker, non-covalent interactions, such as Van der Waals forces, pi-interactions and hydrogen bonds. Each of these interactions is further dependent on whether the thermoplastic is compatible, such as the presence of aromatic rings for pi-interactions.
Making It Stick
With those challenges in mind, how can thermoplastics be coaxed into forming a significant interface with CF? As noted in the earlier cited work by Sameh Dabees et al., there is no single surface treatment for CF that would work for every thermoplastic polymer, as a logical result of the limitations imposed by the available non-covalent interactions.
One way to prepare the CF is by applying a coating to the fiber, called a sizing. By applying a sizing to the fiber that is compatible with the target thermoplastic, the interface with the bulk material is expected to improve. In one cited study involving a polyamide-acid sizing for polyimide bulk material, this coating created an approximately 85 nm interface, with an interfacial shear strength increased by 32.3%. In another study targeting CF-PEEK, this had a polyimide-based, water-soluble sizing applied that also significantly improved the shear strength.
Of course, this sizing has to actually adhere to the CF, lest it simply vanishes into the bulk thermoplastic material. This is a problem that is easily observable in FDM-printed thermoplastic polymers as distinct voids around the CF where the bulk polymer pulled away during crystallization, and no interface formed. Obviously, these voids create a weak point instead of strengthening the material.
Fiber Modding
Although CF is often confused with carbon nanotubes, it does not have the rigidly ordered structure that they do. Instead it has a graphite structure, owing to the way that they are produced, meaning sheets of graphite placed together in a disordered fashion. Despite this, the external surface is still smooth, which is where the chemical inertness comes from. Combined with the lack of reactivity from the side of thermoplastics, this highlights the need for something to bridge the gap.
The review paper by Dabees et al. covers the most common types of surface treatments, with the above graphic providing a summary of the methods. Perhaps one of the most straightforward methods is the coating of the CF with an epoxy, thus shifting the interface from CF-thermoplastic to thermoset-thermoplastic. This kind of hybrid approach shows promising results, but is also cumbersome and not a universal fix.
Note that virtually all research here is focused on thermoplastic polymers like polycarbonate and PEEK, as these are most commonly used in industrial and medical settings. Yet even within that more limited scope the understanding of the exact effects of these modifications remains poorly investigated. Much of this is due to how hard it is to characterize the effects of one treatment when you take all other variables into account.
Perhaps most frustrating of all is how hard it is to research this topic considering the scale of the CF surface and the miniscule thickness of the CF-polymer interface. Relying on purely mechanical tests to quantify the impact is then tempting, but ultimately leaves us without a real understanding of why one method seems to work better than another.
Vibes Vs Science
The overall conclusion that we draw from this particular review paper is that although we know that composite materials can often provide improvements, in the case of thermoplastic-CF composites we realize that our understanding of the fundamentals is still rather lacking.
Outside of the less mainstream world of industrial and medical settings, CF is now widely being added to thermoplastic polymers, primarily in the form of filaments for FDM 3D printers. Without detailed information on whether the manufacturers of these filaments perform any kind of CF surface modification, it is very hard to even compare different CF-polymer filaments like this, even before taking into account individual FDM printer configurations and testing scenarios.
Considering that CF has for a few years now been identified as a potential carcinogen akin to asbestos, this raises the question of whether we really want to put CF and particularly the very small chopped carbon fibers into everything around us and thermoplastics in particular. When the empirical evidence available to us today shows that any mechanical improvements are not due to a solid CF-polymer interface, and any potential carcinogenic risks still years into the future of becoming clear, then the logical choice would be to hold back on CF-thermoplastics until we gain a better understanding of the benefits and risks.
This reminds me of the “smelting” cislunar experiments on, I believe, Apollo 14 or 15. One of the experiments involved casting a metal containing a fibrous material to determine if such a thing manufactured in space would work better than the same produced in a 1G field; whereupon the fibers tended not to distribute homeostatically, but clumped in the “down” direction.
I should say “homogeneously”. :/
Get off my back – I haven’t received my coffee injection yet, so I’m not homeostatic!!
It’s 2026, you’d think we got edit button on HAD by now.
no.
no it does not and it has always made me roll my eyes when people bragged about it being solely the only thing they used
when you present them with this information they start babbling about texture as if matte pla and foaming pla didn’t already exist its absurd.
Amongst those making firearm components via fdm, it is fairly well understood that any additive will adversely impact strength and layer adhesion, but materials like nylon, PPS, etc. are lacking in rigidity or are otherwise difficult to print, which carbon or glass fibers remediate quite well.
Problem with this whole “scandal” is that even with the voids, the CF is still partially bonded to the PLA. It’s easily demonstrated that CF parts have altered strength qualities. Maybe it’s not working the way we thought or as well as we would like, but it still works.
I’m not sure I’d classify it as ‘bonded’, unless you can show that an actual interface using non-covalent bonds has formed between the CF and the polymer matrix. In the absence of that the ‘bond’ will tear away at the merest mechanical provocation, making the position of a CCF in the matrix a pure void and thus weakness.
I’m curious and know nothing about this. Why only non-covalent bonds? Would there be something wrong with covalent bonds between the materials?
Upon rereading the article, I understand that you mean specifically pi-interactions or Van der Waals.
I’ll add that Van der Waals can be surprisingly strong when there is a large surface of interaction.
Various people have tested the strength of carbon fiber PLA prints vs. regular PLA prints and found that the CF actually makes it more brittle. Pretty, but brittle.
I don’t know almost anything about CF in PLA. What I do know a bit about is metal matrix composites, which are somewhat similar. Ceramic material in a metallic matrix, and in an analogous way, the stuff that had long (aspect ratio greater than 100) fibers, there were significant improvements in tensile strength, but most production of MMC was/is just very small chunks of aluminum oxide in aluminum, and what that produced was improvements in compressive strength and elastic modulus. That’s exactly what I’d expect: if there’s no fiber, there’s no real change in tensile strength aside from the significant possibility of delamination between the heterogeneous elements reducing tensile strength.
Which I think is a pretty strong indicator that we shouldn’t even bother looking at cf filled pla as regards tensile strength, especially because even if it were semicontinuous it wouldn’t be able to bridge layers, but instead where the cf added this way might be useful: changes/increases in stiffness.
I can’t speak for all people who 3D print, but there seems to be a misunderstanding as to why these fibers are added to filaments. For the most part, it isn’t to improve strength, durability or otherwise (though I have seen some manufacturers make such claims). The main reason is enhanced printability, particularly for materials like PA, PC, and PP, as adding CF-tow significantly reduce print warping and has a matte finish that hides layer lines. And in that regard CF is not the only method utilized, as cheaper (though denser) glass fibers are also used/substituted. Glass fibers also offer a different feel for those who have sensitivity to handling carbon strands.
Perhaps people aren’t looking at the right parts of youtube, but folks serious about material comparisons in 3D printing such as prof Igor Gaspar of MyTechFun have tested various CF material blends over the years and consistently point out that it’s all a tradeoff- you get better printability/visual surface quality, often at the cost of layer adhesion. It’s not like this is new information, which is why the arguments of “CF filament=bad” solely due to mechanical “improvements” either feels like it’s addressing a completely different 3D printing community or is just a strawman.
It’s easy to imagine a wake of untruthful advertising following the FibreSeeker 3 media attention. The group of people one can sell inferior chopped CF composite filament to* likely also coincides with people for whom this is indeed new.
* something that has CF in the name and which they’re able to print on their machine
Cons: all of them
Pros: “but I like the way it looks!”
Every time I receive a product extended from chopped carbon fiber impregnated filament I send it back and compel a refund. I’ve even had people send me things you use on your face beat your eyes printed from CF. Unacceptable.
Terrible gboard.
extended = extruded
beat = near
Im gonna say no. It looks kind of cool but it has much worse layer adhesion than regular PLA. I also saw bunch of tests where it performed much worse than regular PLA with only execption being some directional stuff which didnt seem to matter too much. Also, wears nozzles like crazy.
I do like how it looks. Anyways, when I finish my current CF PLA supply I will not be buying more.
I have used the protopasta cf-pla filament. And its one big difference is that is it stiffer than normal pla. I don’t know if its it stronger but there are times when rigidity is what I want. Additionally it prints very nicely.
stratasys makes a Nylon 12 and a Nylon 12 CF. the CF nylon is much stronger — much higher tensile modulus. is that not evidence enough?
